Users will experience an SQL error, because the SQL server has been temporarily disabled, due to an issue.
Thanks, i was just about to let you know about this... :)
Oh while Im here....
When starting the toolkit, if there is no internet access,
the toolkit of course says it cant connect, but then it just
locks up... Cant even close it... Have to go to taskmanager
and close it... Just to let ya know :)
Oh and another one...
Just got through running a live install.
Used the newest version of the toolkit to integrate all addons...
After the install, NONE of the registry files were imported...
All programs and such were compied to the correct place, but
all registry entries in all addons were not applied.
I had this problem with beta 14 also...
Went back to using 0.7.0.50 and the problem is gone???
Edited by *Reaper*
Windows 7 Toolkit v0.8.5 Beta W7T 0.8.5.
Edited by MBrys331
Windows 7 Toolkit 0.8.5.20 beta - no message about no internet; instead:
When started get: Error reading database
Host '71-80-132-232.dhcp.bbcy.ca.charter.com' is not allowed to connect to this MySQL server
Button: OK
Title Bar: Windows 7 Toolkit 0.8.5.20 Beta (Not Responding)
Click X closes
W7T085-21B
Windows 7 Toolkit is much better thank you for your creation
i wish there was more features that can be removed with it
i wish that the program could be alot bigger then it is know!!
Keep up the wonderful work that you create {Project} :thumbsup_anim:
Edited by MBrys331
More Tweaks Windows 7 Toolkit
20 ms Mouse Hover Time
Cache more Icons
Disable kernel paging Optimize Core System Performance
Force keep positive entries in DNS Cache for only 4 hours instead of the default 24 hours
Stop caching negative responses
BootOptimize
get rid of the Windows Mail splash screen
Add Take Ownership
Speed up shell response
Mouse_Hover_Time_speed
LargeSystemCache
Fast_MenuShowDelay
Edited by MBrys331
