THIS WILL ENABLE QUICK LAUNCH CLASSIC LOOK AND FEEL ON WINDOWS 7 VERSIONS
Never got tired of the new look in windows 7? Well i did. And found a way to make the taskbar look like good old XP days.
I started this topic some time, now after i wanted to reformat again. I took some time to look into the code again and make some improvements to the tool.
Quick Launch Classic 7 version 1.05 change log
Legend:
* = New feature
+ = Improved feature
! = Fixed bug
? = Other stuff
01. + Reduced mouse speed while performing action, should finally fix all those errors.
02. + Corrected the mouse to be more precisely now, when working with class/text field.
03. * Added international language support for all in one. USA, France, Netherlands, Denmark, Sweden, Norway, Germany. Your language not supported? Write in the thread.
04. * Added modification from following users at msfn.org, myselfidem, coucou.
05. * Added show dekstop action via mouse. This will fix programs running in the background that could lead to naggin Quick Launch Classic 7, while it was on duty.
06. * Added tray msg in start that to inform the user they should not touch anything, while its running.
07. * Added tray msg when finished.
08. * Added hotkey to exit the program if something went wrong. The key is F1.
09. * Added Quick Launch string check.
10. * Added wait check before continue after ending - starting explorer.exe.
11. * Added switchless params for more info run Run "QuickLaunchClassic7.exe /?"
I suggest for the full joy and effect of quicklaunch classic 7 use following paramf.
Usage run "QuickLaunchClassic7.exe /NOPIN /TGL /TSI /AUTOTRAY /LBS3 /EXPLORER" without the quotes!.
/NOPIN
Removes The pinned list on windows 7 taskbar.
/TGL
Makes Taskbar buttons = Never combine
/TSI
Makes Small icons on windows 7 taskbar.
/AUTOTRAY
Disable AUTOTRAY on windows 7 taskbar.
/LBS3
Langbar is closed and will not be visible inside windows 7 taskbar.
/EXPLORER
Will end explorer and start it again with all options saved, This is usefull so you dont have to restart windows at all to take effect of changes
Quick Launch Classic 7 version 1.04 change log
01. ! Fixed EnableAutoTray
Quick Launch Classic 7 version 1.03 change log
01. ! Fixed typo.
02. * Added EnableAutoTray value 0
03. * Added silent versions for unattended install.
Quick Launch Classic 7 version 1.02 change log
01. * Added Reg Entries
02. * Added Small Icons
03. * taskbar be allowed to move.
04. * taskbar to default value, else the script will not work. You can change back after.
05. * Forced TaskbarGlomLevel = 2 = Never combine.
Quick Launch Classic 7 version 1.01 change log
01. ! Fixed Danish version.
Quick Launch Classic 7 version 1.0 change log
*+!? Intial
Downloads:
Version 1.05
MediaFire
http://www.mediafire.com/?7kgdo8kb5q65mzv
RapidShare
http://rapidshare.com/files/446670274/QuickLaunchClassic_1.05.zip
Old Versions:
Version 1.04
ENGLISH + SOURCE
http://www.multiupload.com/VFVKMOTN7D
DANISH + SOURCE
http://www.multiupload.com/CWZSMKM60B
Version 1.03
ENGLISH + SOURCE
http://www.multiupload.com/YFKXANVJ3X
DANISH + SOURCE
http://www.multiupload.com/ZZ2H5N7TAV
If you wanna translate feel free to it, provide me with links after and ill update the links.
Edited by wazer
