Makcalable Posted February 13, 2011 Posted February 13, 2011 This Is Just A Quick Guide On How to change Advanced Appearance Settings Below I Have Shown A Couple Of Examples;I tried to make this guide as simple as i could Right click on a empty space on the desktop and click on Personalize;Click on Window Colour; Click on Advanced Appearance settings;Select the Item that you want to Modify;(Not all of these items will have the option to change the font/size/colour)Example 1How To Change the Font > Size > Bold > Italic > for Icon's;1. Click on the drop down menu under Item then select Icon2. Now use the drop down munu under Size and select your required size.3. Now select B for Bold to make the text more predominant.4. Now select I for Italic to change the style.Ok now you have changed your Font Size and Style for your Desktop & personal folder's.Example 2How to change the Active Title Bar > Fonts > Size > Bold;1. Click on the drop down menu under Item then select Active Title Bar2. Now use the drop down menu under Size then select your required size.3. Now select B For Bold to make the text more predominant.4. Now select I for Italic to change the style click on the Italic Button to highlight as you did above for the Boldness.5. Now to change the colour there are 2 boxes to choose from here.Now these are just a couple of examples but there are so many things you can change to re style the way your windows look.Now it looks hard but it is really easy.So go on have and have a bit of fun! Quote
