Posted April 2, 201113 yr Logo sourceChangesWinRAR 5.00.0 (32-bit), English Only, 40-days trialWinRAR is a powerful archive manager. It can backup your data and reduce the size of email attachments, decompress RAR, ZIP and other files downloaded from Internet and create new archives in RAR and ZIP file format.Using WinRAR puts you ahead of the crowd when it comes to compression by consistently making smaller archives than the competition, saving disk space and transmission costs.WinRAR provides complete support for RAR and ZIP archives and is able to unpack CAB, ARJ, LZH, TAR, GZ, ACE, UUE, BZ2, JAR, ISO, 7Z, Z archives.WinRAR offers a graphic interactive interface utilizing mouse and menus as well as the command line interface.When you purchase WinRAR license you are buying a license to the complete technology, no need to purchase add-ons to create self-extracting files, it's all included.WinRAR is easier to use than many other archivers with the inclusion of a special "Wizard" mode which allows instant access to the basic archiving functions through a simple question and answer procedure. This avoids confusion in the early stages of use.WinRAR offers you the benefit of industry strength archive encryption using AES (Advanced Encryption Standard) with a key of 128 bits.WinRAR supports files and archives up to 8,589 billion gigabytes in size. The number of archived files is, for all practical purposes, unlimited.WinRAR offers the ability to create selfextracting and multivolume archives.Recovery record and recovery volumes allow to reconstruct even physically damaged archives.WinRAR features are constantly being developed to keep WinRAR ahead of the pack.This addon has the following default features:Default association: .rar with WinRAR1) Associate 4 file types: .7z, .cab, .iso & .zip with WinRAR as default. Rest are not associated.2) Default is cascading context menu3) Default theme is Metro UI. Comes with additional 3 themes, SmoothGreen, Windows 7 & Tulliana4) When uninstall, .cab & .zip are restore to XP defaultUser tweakable choice within inf:1) User can turn off file association for the following individual format: .7z, .cab, .iso & .zip(Please also turn on/off the appropriate [uninstall] section.)2) User can disable cascading context menu by changing [CurrentUser.AddReg] key3) User can override default Metro UI theme and choose any of the 4 themes as default4) If you have the licence, you can include your licence file. See inf for detail.5) If you do not know how to edit the inf, please ask for help here.Comes with 4 selected themes as belowMetro UI by Silviu-Eduard (bundled with permission, thanks)WinRAR500_ENUx86_inf_addon_Trial.cabSize: 2.52 Mb (2,645,773 bytes)MD5: 4C1045A5DAF7AECFC9129C229A4BDA6B Edited September 19, 201311 yr by Geej
November 30, 201113 yr Author Updated to v4.10 beta 4Add 1 more theme: Windows 8 Metro UI, by Silviu-Eduard and set as default theme.
November 30, 201113 yr Hi, GeejThis is a perfect work!Can you make svcpack addon same properties this addon pls? (Same default metro ui etc.?) Edited November 30, 201113 yr by oguz
December 1, 201113 yr Author Hi, GeejThis is a perfect work!Can you make svcpack addon same properties this addon pls? (Same default metro ui etc.?)Thanks.You can easily DIY by converting to silent installer with WINRAR.The winrar sfx installer should contains only 3 files: 2 cabs files + winrar4.infUse the below comment file;The comment below contains fully silent SFX script commandsSetup=rundll32.exe advpack.dll,LaunchINFSection winrar4.inf,Install,3TempModeSilent=1Overwrite=1
December 15, 201113 yr Beta 5 is released Can you make some time svcpack addon this addon pls? (default metro ui etc.?)
December 17, 201113 yr Author Hi all, updated to 4.10 beta 5====@oguz, I repack 1 time for you : svcpack methodWill host for 7 days or earlier. Pls modify slightly at your end the [Del.i386] section in future if you wish to convert to svcpack.For some unknown reason, the sfx does not execute from temp dir, so I have to del from current dir after normal installation.It is not really necessary to modify [Del.i386] if slipstream from svcpack.infHowever if you normal install, then it is better to modify as it can't remove the extracted files after installation.[Del.i386]RUNDLL32 advpack.dll,DelNodeRunDLL32 %1%\i386,8RUNDLL32 advpack.dll,DelNodeRunDLL32 %1%\WinRAR4.cab,8 ;additional command for normal install onlyRUNDLL32 advpack.dll,DelNodeRunDLL32 %1%\WinrarTH.cab,8 ;additional command for normal install onlyRUNDLL32 advpack.dll,DelNodeRunDLL32 %1%\WinRAR4.inf,8 ;additional command for normal install onlyWinRAR410B5_ENU_svc_addon_Trial.cabSize: 2.4 Mb (2,519,067 bytes)MD5: 20A2EE8E49361597DCC4B6B07BE0BDA3
January 18, 201213 yr Author Updated to v4.10Also replace Reborn theme with SmoothGreen theme.Metro UI is still the default theme
February 21, 201213 yr Winrar 4.11 is released ...http://www.filehippo.com/download_winrar_32/By the way can i make a request?Would you please make an addon for 64 bit in addon to 32 bit version?Thank you.
February 23, 201213 yr Author Updated to v4.11@oguz, I do not have x64 OS to test. Don't think I can made x64 addon. Sorry
