Posted April 9, 201113 yr Here you go. I waited a really long time before saying, screw it. I'll make it myself. This is specifically made for Windows 2003.LINKIt is also updated with the latest KB 2483614 update.This is a true addon, and it only works via integration since this addon replaces files in the i386 directory, instead of using a cab file
April 10, 201113 yr Did you know you can go even further and take the Remote Desktop Connection from Windows 7 SP1 and make a true replacement addon?Just make sure to get the CAT that digitally signs itBTW the latest hotfix for RDC SP1 is KB2522743So if you want the very latest takes the files that have been updated in SP1 and the ones from that hotfix above and you will have the very latest Remote Desktop Connection possible
