Ok..the thing is , i've downloaded all the Solor's Updates , integrated them with w7t into the image and burn it to the stick.(reason-> High Capacity). Every went well untill Installing updates...after reboot..nothing , the computer entered into recovery console and said my windows is damaged..the funny thing is i've tried this on vmware and on Virtual PC..in both cases NONE of them worked..
i have 2 images...x86 and x64 and i added updates only for x64. My question for you gyuys ...ytou used solors updates, integrated them with w7t and your dvd/stick worked ? and if it did , please guide me.
i merged the two images , i integrated the updates , made some tweaks and that's it.. created an iso and then tested on vmware and virtual pc. same thing happened both times.
live, the same.
now i've tried the 3rd time...the same.
Lego , the background images ...add stuff ...the tweaks in the tweak section. those tweaks...nothing more..
