Posted May 11, 201113 yr HomepageThe sound is automatically muted when the computer is turning off or is going to sleep/suspend mode. There is an option to mute sound when screensaver appears. So the next system start is absolutely silent even if you forgot to turn the sound off in previous session. After restart you can unmute sound effects manually, using a shortcut combination (Ctrl+F10). Moreover, you may use this keyboard shortcut to quickly switch the sound on and off when working.Note: Auto Startup itemAuto_Mute_3.9_inf_addon.cabSize: 281.28 Kb (288,027 bytes)MD5: 22586D2D009885135F0F8F9218F9A9A0
