Posted June 7, 201113 yr Instruction:1. Export HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts from registry2. Leave fonts which you want to integrate and save key3. Open W7T > Addon Creator4. In "Add Files" Enter patch to your fonts5. Copy directory is %windir%\Fonts\6. In "Import Registry" Add your saved registry key7. Click "Create Addon"8. Integrate created with All-In-One IntegratorThat`s all. Now You can integrate fonts with easeTemplate Addon with fontsDownload from MediaFire-EDIT-Little Edited instructionAdded screenshostsAdded template addon Edited June 11, 201113 yr by LYSY
June 8, 201113 yr could you explain the steps adding screenshots?Creating a W7T addon is similar to this process in this video
June 11, 201113 yr could you explain the steps adding screenshots?Updated.Now tutorial is with screenshots, is little updated, and added Template Addon
June 11, 201113 yr You can also just copy the fonts to the Font dir and run FontReg once and the registry entreis will be created (you can also place fontreg in the same dir as the fonts and it will copy and register them)
