Posted June 9, 201113 yr HelloI will wish to integrate into a custom INF file command "attrib.exe" to hide when I install my windows 7 "StartUp" folder (%APPDATA%\Microsoft\Windows\Start Menu\Programs\StartUp). anyone have any track.Cordially
June 9, 201113 yr If you mount your wim you can apply the attrib +h command to the folders this will carry over to your install (keep in mind there are two \Startup folders)INF code it would go something like this:; File/Folder Attributes; R=1; H=2; S=4; HS=6; SHR=7HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\MyProg",,,"%16386%"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\MyProg",FOLDER,,"Startup,2"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\AllProg",,,"%16407%"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RenameFiles\AllProg",FOLDER,,"Startup,2"
