Posted June 17, 201113 yr Hi, i hope i'm in the right place. over a few hours of googling hasn't proved any help at all..a friend of mine had his PC crash (bad virus) and i pulled his data off his hard drive for him and then restored it. All was good except for his outlook profile. Which isn't just outlook.pstthe files he has are outlook.pst outlook_part2.pst, Outlook_part3.pst, and outlook_part4.pstHowever none of them outlook sees as .pst files. it just says "(filepath)\outlook.pst is not a Personal folders file" regardless of which one i used.he says he never split the files. So what exactly happened? Is all his outlook data gone?
June 17, 201113 yr .pst files might be corrupted.Have you tried to repair .pst files?http://office.microsoft.com/en-us/outlook-help/repair-an-ost-or-pst-file-in-outlook-HA001056300.aspx
June 17, 201113 yr Author .pst files might be corrupted.Have you tried to repair .pst files?http://office.microsoft.com/en-us/outlook-help/repair-an-ost-or-pst-file-in-outlook-HA001056300.aspxUsed the tool and i can now open the .pst files. however everthing is in a "lost&Found" folder. And there are still 4 of them, Not just 1
June 18, 201113 yr Hmm, those files sound like archives.Outlook by default is moving older e-mails in the arthive.pst, but user is always asked for this action. He might have made these files during the archiving process.Try to open each of these .pst files. If mails are in the lost and found, that is better than nothing. You'll probably have to recreate folders and sort mails as they were before.That was some nasty virus infection eh?
May 12, 20159 yr Hi, I have the same problem, is there an Outlook recovery tool that is able to repair this corruption?I used this and works very fine. Edited May 21, 20159 yr by Basil
