Start Menu X v4.5 ( freeware edition )
The list of menu items is alphabetically sorted, so you can easily find any program or command by its name.
M
- Open any location on your PC with a single click.
You can create, modify, and reorder items in Start Menu 7. So it's easy to create a list of the most used locations, popular directories, and virtual folders to access them with a single click.
- There is a special Run button to access seldom used locations without adding them into menu.
- Start Menu 7 has a customizable Power Buttons panel.
- With Power Timer feature you can delay any of power management operations.
Note: Auto Startup item
Default will copy English.ini only.
Default Start button is Apple
Instruction to change lang / Start Button is in [ How to change to your language setting ] section. It is at the begining of the inf.
Available lang in the addon are as below:
Czech.ini, Danish.ini, Dutch.ini, English.i.i, French.ini
German.ini, Hungarian.ini, Italian.ini, Japanese.ini
Polish.ini, Portuguese.ini, Russian.ini
Simplified Chinese.ini, Spanish.ini, Swedish.ini, Traditional Chinese, turkish.ini
Start_MenuX_4.5_inf_addon.cab
Size: 2.7 Mb (2,828,325 bytes)
MD5: 64E23A7C447CFA914D76B7235B6BF233
  • 9 months later...
