So I discovered this promising-looking tool and immediatelly tried the components removal part. Is it normal that install.wim grew some 40MB bigger after removing more than half of the available packages?
Thanks for the replies. I found out about this pretty soon - inability to read sucks :P The image shrank by about 100MB only - I hope it's so little due to strong compression, because the amount of stuff I checked to remove was high.
Stil a shame there's so little to remove :(
Lego you should add the ability to only un-hide and remove the desired component(s) and leave the others untouched...or the ability after component removal to restore the registry permissions and re-hide the components once more (so it does not affect feature disabling)
Check out this guys explanation to what the install_wim_tweak tool does to un-hide the components (all you need to do is reverse the process)
I asked the author of the install_wim_tweak tool to update it and add the ability to un-hide single components without affecting the rest like so
install_wim_tweak /p C:\mount /m /c <component_name_to_un-hide_here>
The source code is available, hopefully someone can do it or you can add it to your tool
I've already done a few modifications to it myself and fixed quite a few bugs with that tool, it's a great little tool. I will add the feature you are describing to it :) As i said above i'm planning on doing some work to it by moving it to the All-In-One section so it will remove stuff from all the images you select and not just one at a time :(
Make sure you remove the components from all images, then it may shrink more... I'm planning on doing some work on the Component Removal :)
Did you mean from other windows versions from the image? If not I don't understand
edit: Can you give us link to your modified tweaker btw? I am trying to learn some stuff and experimenting with DISM, so I would really appreciate it.
Edited by Octopuss
EDIT: I have completed v1.3.3 which let's you use this tool on the current installed OS but not sure if it actually needs releasing...
Total amount of changes i've done
*the /m is no longer needed, will do the task by default
*fixed a bug where it did not work if there was a space in the mountpath.
*Win32Security.dll file is no longer needed
*Added new colours, errors are displayed in Red
*Fixed bug crashing at end of running
*Fixed bug where it cannot unmount registry if something fails
*Added specific component selection
*Fixed some other bugs
*Added an appropriate small icon for the app
Also normally you will have to put the specific component name i.e.
"/c Microsoft-Hyper-V-Common-Drivers-Package~31bf3856ad364e35~x86~~6.1.7601.17514"
but if for example you put "/c Microsoft-Hyper-V-Common-Drivers-Package" it will show all packages starting with that.
Top picture is on default run whilst bottom is a specific component.
Edited by Legolash2o
As posted on MSFN, i'm now on build v1.3.4 with more another bug fix.
Also, i've managed to get the Component Removal on All-In-One working so you can now remove packages from all Window versions in the image automatically, but it won't be visible until W7T 1.0.3 :)
