Kel has used a guide which started out over on MDL, and was then posted over at Ryan's by user_hidden to create an AIO with x64 recovery options (with x86 as well?). http://www.ryanvm.net/forum/viewtopic.php?t=8993 Kel suggested using Win7Toolkit in place of some of the steps, and I thought that maybe it would be possible to enhance Win7Toolkit to actually replicate the result all on its own? The Toolkit already can do so much, but I figured it wouldn't hurt to ask. It would seem to be a useful addition.
Done, tested and working. Just a few modifications to make to the AIO Maker in general and i also found a big bug which affects integrating addons, silent installers etc... where files would copy and overwrite the files even when it's not supposed to :)
P.S. Is it normal for when i load the x64 recovery mode and select install it asks for drivers? i think it wanted usb ones... (PM me the answer) as this thread will be closed.
Edited by Legolash2o
