Posted August 7, 201113 yr Is there a possibility to hide some icons (=stuff like "Addon Maker", "USB Boot Prep", ..) in every tab ? And hide tab like "Downloads" ?Thanks for your support. Edited August 8, 201113 yr by Legolash2o
August 8, 201113 yr Author Ok that's really good and maybe you may also hide "Converters Tabs" too ? Because i forgot to mention it on the previous post.I find your idea to disable it, in 2 different way (options and tab) is a good idea for me. Edited August 9, 201113 yr by Winterstorm2050
August 17, 201113 yr An update on this... v16+ you will be able to right click a button and make it hide. W7T will then automatically re-arrange the icons so that there isn't a gap where the old button was.Just a note though, All-In-One Tool and Component Removal can't be hidden (done on purpose). Oh and also some buttons around the edge can't be removed either (again, done on purpose).Thread will not be closed, if you wish to add something then PM me and i will re-open the thread.
