MANIKANT.S.GUPTA Posted August 8, 2011 Posted August 8, 2011 It would be great if Toolkit supports the System files replacement with the modified one Quote
Legolash2o Posted August 8, 2011 Posted August 8, 2011 Just make it into an addon using the Addon maker. Quote
MANIKANT.S.GUPTA Posted August 8, 2011 Author Posted August 8, 2011 Just make it into an addon using the Addon maker.Thanks will try today Quote
Legolash2o Posted September 2, 2011 Posted September 2, 2011 I will consider adding a new tab called "Files" on AIO Tool where you can add files and specify where you want them to go. Although i do feel abit uneasy letting people randomly replace system files so i will think about it. Quote
tealc Posted September 2, 2011 Posted September 2, 2011 (edited) I will consider adding a new tab called "Files" on AIO Tool where you can add files and specify where you want them to go. Although i do feel abit uneasy letting people randomly replace system files so i will think about it.for Windows customization, maybe you could only allow specific system files to be changed ?for example,- explorer.exe (constains the Windows Orb)- explorerframe.dll (back/forward buttons in explorer windows)- shell32.dll (icons)It could also be interesting to have one tab to add files in the Windows image ? Edited September 2, 2011 by tealc Quote
sirtex Posted September 2, 2011 Posted September 2, 2011 - explorer.exe (constains the Windows Orb)- explorerframe.dll (back/forward buttons in explorer windows)- shell32.dll (icons)Kinda sad we have to hack .DLLs/.EXEs to get what we want, but glad we can still do that. Quote
Legolash2o Posted October 14, 2011 Posted October 14, 2011 Still feel uneasy adding this feature, however if you want me to add this feature and enough people also say they want it then i will add it. Quote
bphlpt Posted October 15, 2011 Posted October 15, 2011 I know a lot of people like to do this kind of thing, but I don't. Anytime you update anything through WU/MU there is a chance that your customizations will be undone. After that happened to me a few times it got to be "Why bother?" If there is an easy way to undo/redo the customizations at any time on a running system, while not interfering with anything else, then that could be handy/fun/harmless. I personally don't see the big need for this, but I'll go along with what the majority wants.Cheers and Regards Quote
Legolash2o Posted October 15, 2011 Posted October 15, 2011 Exactly If it's there you don't have to use it If more people post on here that they would like it then i'll add, won't take long to implement. Quote
Legolash2o Posted October 20, 2011 Posted October 20, 2011 I'll think i will add this, but if someone complains their system will not boot after they have used this then i will not help or take responsibility for it! Quote
hornet512 Posted October 20, 2011 Posted October 20, 2011 I don't understand what thouse options are.Please add a warning notice: "do not use if you don't know" Or you may add advanced users tab. Idiot users such as me should keep away LOL Quote
