Posted August 9, 201113 yr Hi Lego,could you try to make it possible, that Addons in the SFX-version are abe to be integrated with your great tool ? Here in the german forum of win-lite.de are many of those addons which are always updated:http://win-lite.de/wbb/board195-windows-7/board197-win7-addons/15899-sfx-archive-stand-09-08-11/ .Until now I integrate them with another tool which is also published in the german forum. And it would be easier for all that only one tool is necessary to do all these tasks.RegardsPedilover
August 10, 201113 yr Hello, you can add these using the Silent Installers section, best to use the one in All-In-One tool. When it prompts for syntax/switch... just leave it blank and it will process these fine EDIT: I have done some work, where you can select multiple files for SFX files. If you select multiple files then it will auto add the files to the list with no user input I will close this thread, but if you need to add more then let me know via PM. Edited August 10, 201113 yr by Legolash2o
