I think i have found a bug in this alpha version in windows toolkit addon section as soon as you will add the addons more than five or Six addons it will quit the application.
It would be great if we can add Task Manager, Remove Programs & Features in Context menus as i use most of the time
Posted (edited)
1. Hmm that's strange... does it close when adding to the list or after you press start?
2. Does it always crash on the same addon?
3. Is it possible you can list which addons you have or just attach your profiles.txt?
The other thing will have to go into the request forum otherwise i will forget :)
Edited by Legolash2o
