1) you can add a option to choose which themes want to keep? or a option to remove architecture, characters, landscapes, nature, scenes themes and keep only the default windows 7 theme? 2) you can add new themes. a option to choose which theme be the default would be super. 3) option to remove all screensavers
I n addition to these we should be able to set default gadgets and autostart of Gadgets in first login
Hello, do you have any information regarding how to make the gadgets you want appear by default? is it a registry settings or what? lol
Yes i have the information about it to set the default gadgets if you want i will post it here. Thanks for Considering.
UPDATE:.....
Edited by Legolash2o
  • 4 weeks later...
This can be done with Autounattend.xml file:
<settings pass="oobeSystem">
<component name="Microsoft-Windows-Sidebar" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="[url="http://schemas.microsoft.com/WMIConfig/2002/State"]http://schemas.microsoft.com/WMIConfig/2002/State[/url]" xmlns:xsi="[url="http://www.w3.org/2001/XMLSchema-instance"]http://www.w3.org/2001/XMLSchema-instance[/url]">
<Gadget1>%PROGRAMFILES%\Windows Sidebar\Gadgets\Clock.Gadget</Gadget1>
<Gadget2>%PROGRAMFILES%\Windows Sidebar\Gadgets\Calendar.Gadget</Gadget2>
<Gadget3>%PROGRAMFILES%\Windows Sidebar\Gadgets\Weather.Gadget</Gadget3>
</component>
http://www.msfn.org/board/topic/151292-weather-gadget/
I hope that can help!
  • 4 months later...
In the AIO,can you add an option to integrete Gadgets in the form of folders(that are already installed in the current system in C:\Program Files\Windows Sidebar\Gadgets)
