Legolash2o Posted August 15, 2011 Posted August 15, 2011 (edited) The Language Pack Converter tool converts your langauge packs from the .EXE form to the .CAB form so you can use them to integrate into your Windows image, using either the All-In-One Tool or another program from a different developer.Step 1: Add the Langauge Pack(s)Click the Add button, browse for your language packs.exeStep 2: Starting the processPress the Start button and select the folder you want the .cab to goStep 3: WaitItems that go Green mean they have converted successfully, that's pretty much it. Edited March 28, 2012 by Legolash2o Qunlye, budy, salik and 12 others 15 Quote
LemiToLunay Posted March 10, 2012 Posted March 10, 2012 Quiero añadir la lengua Turca en Windows 7 Programador Toolkit = )) Quote
Legolash2o Posted March 10, 2012 Author Posted March 10, 2012 Quiero añadir la lengua Turca en Windows 7 Programador Toolkit = ))I want to add to the Turkish language or Windows 7 Toolkit ProgrammerWas that asking for help and how to do that? Quote
certuser Posted July 25, 2012 Posted July 25, 2012 Can I use with the home premium version and change the system language ? Quote
Henry Garnique Posted March 4, 2016 Posted March 4, 2016 (edited) En 15/8/2011 a las 2:42 de la tarde, Legolash2o dijo: packs.exe Donde el Ubico "Languaje Packs" de Win Toolkit de la version v.1.5.4.4 Edited March 4, 2016 by Henry Garnique Quote
Celal Kar Posted November 24, 2018 Posted November 24, 2018 ben bu dil değiştirme durumunu bır haftadır çözemedım başaramadım sınır oldum sizden helıkopter istemıyorum .şu dıl değiştırme konusunu daha anlaşılır bır tarif istıyorum saygılarımla. Quote
Celal Kar Posted November 24, 2018 Posted November 24, 2018 ben bu dil değiştirme durumunu bır haftadır çözemedım başaramadım sınır oldum sizden helıkopter istemıyorum .şu dıl değiştırme konusunu daha anlaşılır bır tarif istıyorum saygılarımla.win toolkit v1.0.10- Quote
