Legolash2o Posted August 15, 2011 Posted August 15, 2011 The 'MSP Extractor (MS Office)' lets you convert your Microsoft Office updates into *.msp files which go into the 'Updates' folder of your Office installation disk so that they get installed automatically when you install Office.Step 1: Add your Office updatesClick 'Add Office Updates' browse to them (exe) and wait for them to add into the list, you should then see information about the Office updates you have selected.Step 2: Click StartClick 'Start' and select which folder you want the new *msp files to go.Step 3: WaitSit back and relax whilst W7T extracts the msp files, it will let you know when they are done. chromoma, FreeRyde and ibrahimhajjaj 2 1 Quote
spdboyz Posted July 20, 2014 Posted July 20, 2014 Hi, should I include all the folders or just the .msp inside each of these folder into Office 2013 updates folder? Quote
Legolash2o Posted July 20, 2014 Author Posted July 20, 2014 I just include the *.msp, not sure if the folders will work Quote
spdboyz Posted July 25, 2014 Posted July 25, 2014 Okay...but I'm getting this error during installation. There were cases where some .msp had the same name with another .msp so what I did was add (2) at the end of the filename. Not sure whether the error is caused by this. Quote
Floppy Posted October 16, 2014 Posted October 16, 2014 Hey! Iam using v1.5.2.11.When I use the filter under Tools-->Converters-->MSP extractor, it still extracts Msp's for languges that I have not ticked.I try to keep my Office 2013 ISO as small as possible, only need US UK and NO files. Is this an Error? Quote
Legolash2o Posted October 21, 2014 Author Posted October 21, 2014 This should be posted in the bug forum. I shall have a look at it later though. Quote
