The 'MSU to CAB Converter' converts your Microsoft Updates to CAB files which you can use to integrate into your Windows Image or use the CAB Installer to integrate them into your current OS.
post-10183-0-44120000-1342963407_thumb.p
Step 1: Adding the Updates
Click 'Add Updates' and select the MSU files you wish to convert, you will then see them adding to the list.
Step 2: Click Start
Click 'Start' and select where you want the MSU files to go
Step 3: Wait
Wait for the files to convert, files will go green when once they have done.
Edited by Legolash2o
  • 1 year later...
  • 6 months later...
Similar Content
