My USB HD has about 10GB room on it, but I want to keep other files on the drive there.
Perhaps I may be the only one doing this, but I think since good 16Gb USB pen drives are easy to find under $20USD, I can guess others may want other files on there also.
cheers!
I'm at work at the minute so can't check I this can be done right now, I'll check when I get home.
If I remember correctly it will only take a few lines of code to do this
cool, take your time!
