Posted August 23, 201113 yr Yes W7T does automatically ask whether or not I would like to delete the ei.cfg file in my sources directory. Could this be added as a W7T option not automatically delete the file? (Just to remove the question from being always asked if the file is present.)
August 24, 201113 yr Simple renaming ei.cfg to ei.cfg.bak achieves the same as deleting it but allows you to restore it later.
August 24, 201113 yr Actually the renaming thing might be a good built in option to have.Cheers and Regards
August 25, 201113 yr Author Personally, I do not want to have it removed at all, it is just that I keep getting asked the same question every time I want to do something with the install.wim. I figured if I had an option to tell the W7T to leave the file alone, it would quit asking me.
August 26, 201113 yr v27 will no longer prompt you this, 'Create AIO Disk' has the option to remove it by renaming it to ei.cfg.bakI'm also just adding code that if a ei.cfg is detected it will make the image it is locked to appear green in the list, this should help users know which image to edit. Edited August 26, 201113 yr by Legolash2o
August 26, 201113 yr Just added a feature for WIM Manager with a "Remove/Restore 'ei.cfg'" which lets you remove it and then restore it.
