Posted August 28, 201113 yr Hi.I have some problems here.I have tried to integrate some addons in to the Windows 7 setup, but it doesn't work. I don't know why. It is working only for 2-3 seconds then it is showing me "Completed", but wim image have the same size.Here is my Last Session:*AIO#AddonsH:\W7T130-29A\Sources\Reapers_.NET_Framework_4.0.30319.1_x64_Windows7_Toolkit_AddOn.WAH:\W7T130-29A\Sources\Reapers_Adobe_Flash_11.0.1.98_x64_AIO_Windows7_AddOn.WAH:\W7T130-29A\Sources\Reapers_Adobe_Shockwave_11.6.1.629_x64_Windows7_AddOn.WAH:\W7T130-29A\Sources\Reapers_Java_Runtime_7_x64_Windows7_Toolkit_AddOn.WA#OptionsEnable CMDForce UnsignedPrepare DriversPrompt AddonsPrompt UpdatesSkip Driver ChecksI have W7T in folder H:\W7T130-29A\ and install.wim image in folder H:\W7T130-29A\Sources\ . What am I doing wrong?Another thing. The created install.wim image is not showing me architecture in WIM Manager (It shoud be x64 and not ??).When I tried to integrate some updates, it showed me error that I have to set architecture first, but I don't know how...And last thing, when I unmount The Microsoft Windows PE (Boot.wim), there is after restart WIM manager here again. Is it right?I'm new in this and I would like to integrate some stuff in Windows 7 setup...Thanks. Sorry for my English. Edited August 28, 201113 yr by ArMinO
August 28, 201113 yr OK, this requires a bit of research. It seems that when you captured the image it did not store whether your image was x64 or x86.
August 29, 201113 yr Author So. This is how I captured my image.wim file.1.- I put the original .iso file in to the virtual machine via Daemon Tools.- I found that folder of virtual machine in W7T.- I created install.wim from this machine.2.- I put the original .iso file in to the virtual machine via Daemon Tools.- I copied all files from virtual machine in to the W7T working folder (/Sources).- I found that folder in W7T.- I created install.wim from this folder.Always the same result. Without architecture sign... and updates or addons won't integrate. Edited August 29, 201113 yr by ArMinO
August 29, 201113 yr If you open your custom install.wim with 7zip, there is a [1].xml file in there, can you please attach it?
August 29, 201113 yr Author Hmm... There is no [1].xml file... Some xml files are in sources folder, but anyone has this name.
August 29, 201113 yr In the latest version i have allowed it to let you integrate updates but NOT addons. What program did you use to capture your image? because i mounted my image and then capture it and it shows all the correct info :/It's a shame you can't send me that image Edited August 29, 201113 yr by Legolash2o
August 29, 201113 yr Author Yes... It is a shame.. :no:I used Capture Image option in W7T. And I did that from mounted .iso image via Daemon Tools.
August 29, 201113 yr Try extracting that ISO to C:\Image so it goes C:\Image\Windows\System32, then use the capture tool on C:\Image. The newer version of W7T has a new imagex
August 30, 201113 yr Author Yeah. I get it. With new version it is working like a dream. Thank you for your help. I appriciated that.
August 30, 201113 yr So did it manage to capture the image ok and showing x86/x64, etc?? Print screen of it in WIM Manager would be nice Edited August 30, 201113 yr by Legolash2o
August 30, 201113 yr Author Yes... Now it is showing everything... Here is Printscreen:Miniquestion: How can I remove Home Basic, Home Premium and Professional from Image? I would like to have Ultimate version only...
August 30, 201113 yr Use the delete image button. You can select multiple images at once with the CTRL key.
September 1, 201113 yr http://imageshack.us...s/851/sadm.jpg/*AIO#ComponentsAustralia Local PackCanada Local PackClips In The LibraryGreat Britain Local PackHomeGroupMusic and Video ExamplesMusic and Video Examples (Ringtones)New Zealand Local PackTablet PC ComponentsUnited States Local PackWindows Anytime UpgradeWindows Anytime Upgrade ResultsWindows Gadget PlatformWindows Help (WinHlp32.exe)#ServicesBitLocker Drive Encryption::DisabledEncrypting File System (EFS)::DisabledFax::Disabled#Theme PacksC:\Users\SAFS\CastlesOfEurope.themepackC:\Users\SAFS\Diffusion.themepackC:\Users\SAFS\JoshSommersIllusions.themepack#Tweaks500ms Delay Aero PeekAdd "Open CMD here" to Folder Context-menuAdd "Open Elevated CMD here" to Folder context-menuAdd 'God Mode' to Computer context-menuAdd Take Ownership to context-menu (files)Add Take Ownership to context-menu (folders)Allow 3rd Party ThemesClear Page File at ShutdownDisable Admin SharesDisable Auto Reboot after installing updatesDisable Bandwidth LimitDisable Dr WatsonDisable Drive AutorunDisable Highlighting of new ProgramsDisable IPv6 / TeredoDisable Language BarDisable Low Disk Space NotificationDisable Password Caching in Internet ExplorerDisable Thumbnail CacheDisable User Account ControlDisable Window 7 built-in CD/DVD BurningEnable Gadgets with UAC OffFaster Browsing in IEIE Homepage::http://www.google.com.trKill Services Quicker on ShutdownRemove 'Default Programs' from Start MenuRemove 'Help & Support' from Start MenuRemove 'HomeGroup' from ExplorerRemove 'Libraries' from ExplorerRemove 'Music' from Start MenuRemove 'Pictures' from Start MenuRemove Shortcut SuffixRemove the Action Center iconRemove 'Troubleshoot Compatiblity' from context-menuRemove 'Videos' from Start MenuRemove Windows Mail SplashShow 'Computer' on DesktopShow User Folder on DesktopSpeed-up Access to AVI Media FilesTurn off RSS feed discoveryTurn On Clear TypeUnlimited Simultaneous DownloadsUnlock the taskbarUse small icons on Start MenuWord Warp in Notepad#UpdatesD:\Win7.SP1_Update\x64\Windows6.1-KB971033-x64.MSUD:\Win7.SP1_Update\x64\Windows6.1-KB982018-v3-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2425227-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2476490-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2479943-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2484033-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2488113-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2491683-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2492386-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2503665-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2505438-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2506014-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2506212-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2506928-v2-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2507618-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2508272-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2509553-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2511250-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2511455-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2515325-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2518869-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2522422-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2524375-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2529073-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2532531-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2536275-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2536276-v2-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2539635-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2541014-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2544893-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2545698-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2547666-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2552343-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2555917-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2556532-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2560656-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2562937-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2563227-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2563894-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2567680-x64.msuD:\Win7.SP1_Update\x64\Windows6.1-KB2570791-x64.msuD:\Win7.SP1_Update\x64\IE9\IE9-Win7.CABD:\Win7.SP1_Update\x64\IE9\IE9-Windows6.1-KB2559049-x64.msuD:\Win7.SP1_Update\x64\IE9\ielangpack-TRK.CAB#OptionsEnable CMDForce UnsignedPrepare DriversPrompt AddonsPrompt DriversPrompt GadgetsPrompt SilentPrompt ThemesPrompt UpdatesPrompt WallpapersRebuild ImageSkip Driver Checks Edited September 1, 201113 yr by rulman
September 1, 201113 yr I need your Last_session.ini please and a description of what you added.I've fixed it in v43, its released.EDIT: If someone else has an unrelated problem to the first post, please make another thread. Edited September 1, 201113 yr by Legolash2o
September 2, 201113 yr Although there seems not to Integrated Updated 43 nor 54.What is above the 11 updatehttp://www.2shared.com/file/aCIXkWwc/Last_Session_02-09-2011_1821PM.html Edited September 2, 201113 yr by rulman
September 2, 201113 yr Sorry i don't know what your on about. Where am i supposed to be looking when you say "54", "10 update", "gözüyor UNFINALIZE". Are you saying they are working or not.Also in the picture above can you translate what the words mean in english
September 2, 201113 yr I would integrate far 44but there seems to 54. ini file if you are examined,Not working ;Disable Admin Shares / Disable Language BarApart from these, "IE 9" first starting "Setup with default settings" in settings directly from the pop-up sign in if IE 9. Edited September 2, 201113 yr by rulman
September 2, 201113 yr So your saying you have integrated 44 but 54 have appeared in the list? some packages come built-in with Windows.Whats not working about the ini file?I've fixed Disable Admin Shared but can't see whats wrong with Disable Language BarSo your saying IE9 integrates? Print screen maybe?
September 3, 201113 yr V46 created withThe integrated update "44"Appearing on this list ", 54""ini" file, you will see is the inspection ofIE9Last_Session(03-09-2011_1018AM).ini Edited September 3, 201113 yr by rulman
