That's normal, Windows 7 comes with packages included.
For previous versions, I wonder why something like this came out?
Last release such a thing happened to me a few
What do you think about setting IE9?
Edited by Legolash2o
Right click
Add "Open CMD here" Context-menu to Folder
Add "Open Elevated CMD here" context-menu to Folder
Not depress
Can not work?
CMD screen, the default color setting
"Color-A"
Can be added to a tweak?
Is it possible to delete the default themes (Aero Theme "
Edited by rulman
Yeah that screen is normal on first run, but i suppose there is a tweak which will disable it.
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"DisableFirstRunCustomize"=dword:00000001
"Check_Associations"="no" {This will be useful if you use other browsers and doesn't want Internet explorer to check whether it is default or not}
For more Internet Explorer Tweaks you can see the below post
http://www.wincert.net/forum/index.php?/topic/8743-tweaks-merged/page__view__findpost__p__75262
http://www.wincert.n...dpost__p__75262
You are good at finding tweaks!
