MANIKANT.S.GUPTA Posted August 29, 2011 Posted August 29, 2011 What is LDR placeholders. Whether it should be integrated to offline windows 7 image. Whats the benefit of it. Can anyone help me know this better. Quote
ricktendo Posted August 29, 2011 Posted August 29, 2011 They force the hotfix that supersedes it to install the LDR branch of its files, if you want to force the LDR branch there is an option to do this with w7t so you dont have to integrate them Quote
MANIKANT.S.GUPTA Posted August 29, 2011 Author Posted August 29, 2011 They force the hotfix that supersedes it to install the LDR branch of its files, if you want to force the LDR branch there is an option to do this with w7t so you dont have to integrate themCan you provide more detail, In solor update pack their is LDR Placeholder folder, in which 13msu files are whether we should integrate those files in Offline image, and if yes then what will the benefits of these integrations. Quote
compstuff Posted March 13, 2012 Posted March 13, 2012 Rick,I know I have asked many questions about this and we all know it seems to be a source of confusion so I would like to ask again for your insight and we can get this info included in the new version and guide.Based on what you mention above and the way 1.4 downloads the SoLoR updates and creates a LDR Placeholders folder... if I check the LDR option and want to include the LDR branch do I keep this placeholders folder so the integration sees them and forces the LDR branch or do I delete the folder so that they are not integrated? What is the definitive way to integrate the LDR branch? Quote
jgp Posted March 13, 2012 Posted March 13, 2012 @compstuff - The way I do it is to check the box for LDR option in W7T & removed the folder LDR placeholder. Quote
compstuff Posted March 13, 2012 Posted March 13, 2012 That's what I had been doing but it seems to not be what Rick is stating above...@compstuff - The way I do it is to check the box for LDR option in W7T & removed the folder LDR placeholder. Quote
Legolash2o Posted March 14, 2012 Posted March 14, 2012 I think there was a bug between v1.3.0.102 and 1.4.0 Test 8, should work in test 9 Quote
