Chares Posted September 6, 2011 Posted September 6, 2011 (edited) Hey,i think i've seen it before running on DISM once, or inside System Center Configuration manager,there's a way for a program that uses DISM, or maybe it needs to be programmed to detect, when youre adding a driver different from the architecture of the source.wim.I'll explain further in an example:A.- If you try to add a x64 driver to an x86 source.wim, it will throw you an error, and vice versa.B.- If the driver is multi-architecture, let the user know, it runs on both.is this possible for WT7 ?Cheers, Edited October 8, 2011 by Legolash2o Quote
Legolash2o Posted October 8, 2011 Posted October 8, 2011 (edited) I'll just this a try EDIT: Below i have added a column which shows if the drivers is x86, x64 or Mix (both). Some older inf files don't say what architecture they are so i have programmed W7T to assume they are x86. I will add some of the other requests in your initital thread later on (maybe tomorrow) as i have work soon. Edited October 8, 2011 by Legolash2o ioganlopezz and mytikettenden 2 Quote
Legolash2o Posted October 14, 2011 Posted October 14, 2011 (edited) As well as the addition to above, i have made drivers which are NOT mean't for the OS you have selected they will appear in red, you can then use the 'Remove' > 'Remove All Invalid (Red)' option at the top (W7T v50) to remove them all in one go.I believe this is much better because if you 'throw you an error' it would do it for each one which would be very annoying so the method i have implement is much quicker!EDIT: This request is finished, closing.... Edited October 14, 2011 by Legolash2o Mr_Smartepants and Chares 2 Quote
