Posted September 22, 201113 yr WhatInStartupDescriptionThis utility displays the list of all applications that are loaded automatically when Windows starts up. For each application, the following information is displayed: Startup Type (Registry/Startup Folder), Command-Line String, Product Name, File Version, Company Name, Location in the Registry or file system, and more.It allows you to easily disable or delete unwanted programs that run in your Windows startup. You can use it on your currently running instance of Windows, as well as you can use it on external instance of Windows in another drive.WhatInStartup also supports a special "Permanent Disabling" feature - If a program that you previously disabled added itself again to the startup list of Windows, WhatInStartup will automatically detect the change and disable it again.Changelog:•Version 1.35: ◦Added 'Auto Size Columns+Headers' option. ◦Added x64 build.Version: 1.35Addon Release Date: July 2, 2013Shortcut created in: Control PanelUninstallable: YesCredit: *Reaper* (x64)64.1 kbd5173ed917e38091cdada0d546fe4bef (x86)55.5 kb47cc87aa305acf1d7ada1106868f8e87Enjoy! Edited July 2, 201311 yr by *Reaper*
October 30, 201311 yr I'm verifying now all ''my'' addons for both x86 and x64 builds, and I've noticed one single problem - WhatInStartup is not uninstalable (both for x86 and x64). No biggie / no hurry, please check once version 1.36 is out. Thanks!
October 30, 201311 yr Author Hmm... Does it give a error or is it not visible or what... I just checked my x64 and it uninstalled fine...
October 31, 201311 yr How did you uninstall it? It doesn't have a shortcut either in control panel's Programs and Features, either in Start Menu. The ''request'' was to make such an uninstall shortcut somewhere (preferably in programs from control panel) that works. And no, no other errors. The program via the control panel shortcut works just great, both on x86 and x64 versions
October 31, 201311 yr Author After you go to Programs in the control panel, in the upper left corner, click "view installed updates" You should have it there under "Reapers Control Panel Pack Addons"
October 31, 201311 yr Pretty hidden if you ask me. But it works, just uninstalled on my x86 system. Please consider this optional request, to move the uninstall shortcut to the main Programs and Features location. Thanks
