mooms Posted October 11, 2011 Posted October 11, 2011 Everything est un logiciel gratuit et très léger qui indexe presque instantanément tous les fichiers contenus sur votre PC.Très pratique lorsque vous recherchez un fichier, vous n'irez plus jamais ouvrir le dossier, vous tapez son nom ou une partie et il apparait. Vous ne pourrez plus vous en passer !Astuce: Ctrl+molette souris sur la fenêtre de Everything vous permet de zoomer le texte.- AddOn inf compatible nLite et RVMi- Installe Everything en français à T-13- Démarrage auto de Everything.- Installable en live (clic droit sur le fichier inf -> installer) (possibilité de maj depuis version précédente)- DésinstallableTaille: 599 KoMD5: c9ed79db4707968e19ed1eb9b69b27f7mediafire: Everything_1.3.3.658b fr_inf_AddOn.rarun extrait de la FAQ:1.1 What is "Everything"?"Everything" is an administrative tool that locates files and folders by filename instantly for Windows.Unlike Windows search "Everything" initially displays every file and folder on your computer (hence the name "Everything").You type in a search filter to limit what files and folders are displayed.1.2 How long will it take to index my files?"Everything" only uses file and folder names and generally takes a few seconds to build it's database.A fresh install of Windows XP SP2 (about 20,000 files) will take about 1 second to index.1,000,000 files will take about 1 minute.1.3 Does Everything search file contents?No, "Everything" does not search file contents, only file and folder names.1.4 Does "Everything" hog my system resources?No, "Everything" uses very little system resources.A fresh install of Windows XP SP2 (about 20,000 files) will use about 3-5mb of ram and less than 1mb of disk space.1,000,000 files will use about 45mb of ram and 5mb of disk space.1.5 Does "Everything" monitor file system changes?Yes, "Everything" does monitor file system changes.Your search windows will reflect changes made to the file system.1.6 Is "Everything" free?Yes, "Everything" is Freeware.1.7 Does "Everything" miss changes made to the file system if it is not running?No, "Everything" can be closed and restarted without missing changes made to the file system (even across system restarts)."Everything" updates the database when it is started.1.8 What are the system requirements for "Everything"?"Everything" will run on Windows 2000, XP, 2003, Vista, 7 and 8."Everything" will only locate files and folders on local NTFS volumes."Everything" requires administrative privileges for low level read access to volumes. Quote
ajpan Posted January 26, 2013 Posted January 26, 2013 Il existe une beta plus récente (Everything-1.3.0.632b) qui a amélioré l'interface des options, laquelle était assez obscure. http://www.voidtools.com/ Quote
mooms Posted January 26, 2013 Author Posted January 26, 2013 Oui je sais. Je n'ai pas encore eu le temps de maj celui-ci.Il existe un addon dans la section internationale en attendant. Quote
mooms Posted January 31, 2013 Author Posted January 31, 2013 Maj de l'AddOn: Celui-ci est désormais au format inf, ce qui permet le démarrage auto dès le premier démarrage et la désinstallation. Quote
mooms Posted May 4, 2013 Author Posted May 4, 2013 maj changelog:Saturday, 4 May 2013: Version 1.3.2.647b fixed an issue with creating threads fixed an issue when sorting files with invalid sizes fixed an issue with file lists duplicates fixed an issue with the everything filter moved etp/ftp/http servers to optionsThursday, 18 April 2013: Version 1.3.2.645b fixed a crash when reading extended file info fixed an issue with sending http files.Saturday, 13 April 2013: Version 1.3.2.644b fixed a crash when the index contains duplicated folders Thursday, 11 April 2013: Version 1.3.2.643b fixed a crash when sorting Thursday, 11 April 2013: Version 1.3.2.642b added ETP/FTP server added HTTP server added always ontop option fixed a crash when renaming a file or folder reset keyboard shortcuts Wednesday, 20 February 2013: Version 1.3.1.636b added %APPDATA% option added Everything service option added search history option added the option to cancel locked queries after one second added context menu customization added tooltips for hidden items added option to not compress database fixed an issue with right to left text rendering fixed an issue parsing literal ops fixed an issue expanding filter searches fixed an issue parsing macros fixed an issue when sorting by size with a selection fixed a db event issue fixed an issue with wildcard exclude filters improved db locking mechanism Quote
mooms Posted May 24, 2013 Author Posted May 24, 2013 maj Tuesday, 7th May 2013: Version 1.3.2.649bfixed an issue with matching whole wordsfixed a crash when requesting type informationadded client servicefixed a crash when requesting admin privilegesfixed a crash when displaying corrupt icons Quote
mooms Posted July 11, 2013 Author Posted July 11, 2013 maj Wednesday, 26 June 2013: Version 1.3.3.658b fixed an issue with monitoring icons and file info cache fixed a crash when canceling a sort fixed an issue with threads live locking Monday, 24 June 2013: Version 1.3.3.657b fixed an issue when installing the service fixed an issue with the IPC and x64 fixed an issue with search as you type fixed an issue with unnecessary db rebuilds improved type name sorting Thursday, 20 June 2013: Version 1.3.3.656b fixed an issue with updating icons. fixed a crash when sorting folders by size. fixed a crash when updating folder indexes with an excluded folder. improved sorting Sunday, 16 June 2013: Version 1.3.3.653b added recent changes added run history added home page added x64 build fixed a crash when deleting or renaming a folder with a short file name Quote
