I don't know if I should have created a new thread but I would like the ability to disable compents rather than completely removing them. For example I might want to have Gadgets later on but i don't want them on by default.
  • 4 months later...
I remembered in RT7lite, you can enable or disable windows features just like what are normally done in Control Panel -> Programs and Features -> Turn Windows features on or off.
I think this will be very nice, because Hyper-V is very useful, and if you enable it after installation, it will require a restart, which is very annoying.
Even only an option to enable hyper-v in tweaks of wintoolkit (like enable .net 3.5) will still be very helpful. Thanks!
BUG: By the way, the enabling .net 3.5 in tweaks doesn't work for Win Server 2012 RTM, I still need to mount the ISO and use DISM to manually enable it.
