I would have added this information to the closed topic, but as I cannot (and I did not wish to pollute with another topic), here is the information you requested about running/installing inf files:
The default registry entry for the install under inffile is this:
%SystemRoot%\System32\InfDefaultInstall.exe "%1"
I have also seen other people (Kelsenellenelvian) use the following command:
"%SystemRoot%\SysNative\RunDLL32.exe" advpack.dll,LaunchINFSection Win7Uber.inf,defaultinstall,3
I know there are a couple of other ways to ways to get infs installed using a modification of the last command, assuming of course if those are included into the inf file. I suspect that the default install would be sufficient for most inf install files, but do not quote me on that. ;)
Awesome!! Working with BETA now! Keep up the great work Legolash2o. :thumbsup_anim:
Edited by Legolash2o
