Vizard Posted October 26, 2011 Posted October 26, 2011 Could someone help me understand the importance or benefits of the SoLoR updates?Also...just so i am clear on the updates.....they are updates after SP1 right? Quote
ricktendo Posted October 26, 2011 Posted October 26, 2011 If you want ALL the updates (not just critical ones) since SP1 then you want to use SoLoR's updates Quote
Vizard Posted October 26, 2011 Author Posted October 26, 2011 What is the difference between SoLoR's updates and downloading them myself from M$?Also....thanks for the reply.Just curious about any info on SoLoR's updates because google didn't really provide much info. Quote
Legolash2o Posted October 26, 2011 Posted October 26, 2011 Microsoft release critical updates via Windows Update for anything that will affect the majority of computers, SoLoR updates contains those plus updates which are not released via Windows Updates, i.e. updates meant if you experience a specific problem but personally i download and integrate them all anyway. SoLoR updates are also included in Service Packs so all the Updates which SoLoR provide will be in Win7 SP2. Quote
ricktendo Posted October 26, 2011 Posted October 26, 2011 Microsoft does not provide all its hotfixes via Windows Update, it only gives you the critical updates so hackers dont get into your PC...this does not mean that Microsoft is not busy fixing other small bugs that pop up and they usually release these hotfixes but you have to google the problem you are having and hope that there is a hotfix to fix thatSoLoR gathers them all up in one place and removes any obsolete/superseded hotfixes to save time and space Quote
Vizard Posted October 27, 2011 Author Posted October 27, 2011 I must say thank you for both of those responses....very much appreciated and well explained.After reading this i must give a huge thanks to SoLoR for creating these updates.All of your efforts are appreciated and my questions have been answered....please close the thread anytime you feel appropriate. Quote
Legolash2o Posted October 27, 2011 Posted October 27, 2011 You're welcome P.S. I don't close threads unless it's in the request forum, it just helps me know what requests i've done Quote
p4guru Posted October 30, 2011 Posted October 30, 2011 Hi guys thought I'd also ask in this thread... i use windows updates downloader to download updates and have up to oct 13th, 2011 updates. Rather than download them all again, how would I take advantage of solor updates to download the differences ?? Quote
shon3i Posted October 30, 2011 Posted October 30, 2011 @Legolash2o, one feature request about Solor updates downloader in W7T, can you make ability to sort by date? it's will be much easy to keep upgrade. Also i don't know is possible to follow changelog? Also will be nice ability to download additional hotfixes. Quote
techbound Posted October 30, 2011 Posted October 30, 2011 what i've done for updates is I've created a bat file that uses wget to grab the updates from the windows 7 folder, office 2010 folder, and MSE folder. Atm, it doesn't remove old updates, but i'm working on that. well here's the code for anyone that would like itdel /S /Q *.htmldel /S /Q *.htmdel /S /Q *.logstart wget.exe -m -k -np -c -o win7.log http://hotfix.chris123nt.com/Windows.7/start wget.exe -m -k -np -c -o mse.log http://hotfix.chris123nt.com/Microsoft.Security.Essentials/start wget.exe -m -k -np -c -o office.log http://hotfix.chris123nt.com/Office.2010/the del cmds removes the htmls so you can refresh the downloader. and all output is to a log file. Quote
