windobrico Posted October 26, 2011 Share Posted October 26, 2011 Hello,J' ave 1 problem' - I can to Change Users Folders Location on D:\ = is no good ? Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted October 26, 2011 Share Posted October 26, 2011 It should be ok, personally i haven't tested this but i'm sure someone else has. Quote Link to comment Share on other sites More sharing options...
windobrico Posted October 27, 2011 Author Share Posted October 27, 2011 :ranting:After to have try again, j ' feel regret to confirm you that that doesn't work !!! Quote Link to comment Share on other sites More sharing options...
Etz Posted October 27, 2011 Share Posted October 27, 2011 (edited) Try via Unattended Creator, basically its the only "MS officially supported" way...see if that works...About that option under tweaks, tried myself (before Lego made it also possible via Unnatended) and it works, but only, if you make it for example D:\<Folder>, trying to move it to drive root seems to always fail...Also from my personal experience, if you have multiple users, its much more convinient to use same scheme as Windows already has, basically move it to D:\Users for example. Edited October 27, 2011 by Etz Quote Link to comment Share on other sites More sharing options...
bphlpt Posted October 27, 2011 Share Posted October 27, 2011 It would probably be helpful if you give a little more details than "It doesn't work". WHAT doesn't work? It doesn't accept your change? It doesn't change the location? It changes the location but that breaks something? Your computer catches fire? What? Note what Etz said - you might need to specify a folder on "D:\" for it to work, not just the drive, or try via Unattended Creator.Cheers and Regards Quote Link to comment Share on other sites More sharing options...
