Posted November 3, 201113 yr A request/feature in future release...A separate component in AIO Tool to install Silent Install Updates similar to "Theme Packs" or "Silent Installs + SFX" for the purpose of those KBs that needs to be install silently... Rather than updating the W7 Toolkit every time there's an update that can't be integrated directly and needs to be run @ first boot.or we can just add it directly on "Silent Installs + SFX" component.Thanks and Regards.
November 4, 201113 yr Yes, this was already requested by myself here: http://www.wincert.net/forum/index.php?/topic/8924-adding-non-integratable-updates/. Since it has already been resolved by Legolash2o, this request would already be filled.
November 4, 201113 yr Author @crashflyI miss that topic :doh:@ Legolash2oNot sure if this question has been asked? But is there a way in W7 Toolkit that we can remove updates that's been already integrated? I think its much faster to remove obsolete integrated updates and then integrate updates that are newer or that supersedes...Thanks and Regards.
November 4, 201113 yr Do you mean like this?P.S. You may notice stuff like Upgrade, Support, Picture Samples, WinSXS\Backup, Themes, etc... will show folder sizes.
