zavan Posted November 7, 2011 Posted November 7, 2011 I BEG for the possibility to keep constantly pressed the left mouse button, travel the mouse pointer over the checkboxes and voila!Fast checkbox selection instead of click each one. Mainly for the Component Remover maybe and elsewere.Cheers Quote
Legolash2o Posted November 7, 2011 Posted November 7, 2011 I not sure how to do that but you can select an item, hold shift/ctrl to select a whole bunch then press spacebar and it should tick them. However i will try and add a select all option via right click. Quote
crashfly Posted November 8, 2011 Posted November 8, 2011 I not sure how to do that but you can select an item, hold shift/ctrl to select a whole bunch then press spacebar and it should tick them. However i will try and add a select all option via right click.It is probably less about the option, more on how to do it quickly. Even I did not know there was a shift/ctrl option to select multiple items. We live and learn .... moving on ... Quote
ianymaty Posted November 8, 2011 Posted November 8, 2011 I know nothing about coding and how difficult could be but a selection (mark) with right click like in (norton) Total Commander would be nice. Quote
Legolash2o Posted December 13, 2011 Posted December 13, 2011 I've just finished adding a right click option for v78, i can't think of anything else to improve the situation. Try asking again after v1.4.0 Quote
