HI Legolash2o
i am using windows 7 x64 sp1
there is some problems may i only one have it or many others have it
1-The Drivers for ATI And Nvidia Graphics cards Can not integrated verywell
2-The language packs integrated as express NOT AS INTERNAL and I can not change between the languages from control panel only from vistalizator (after make it
Compatible with windows 7 rtm)
no i do not now
i was convert the language to cab format by your tool
and integrated with the updates
by the way if i make it internal can i change between the languages from controlpanel?
and you do not answer me about HOW CAN I INTEGRATE ATI and NVIDIA DRIVERS
Edited by abuodwan007
Most graphics drivers come in .exe format, which you need to run first and let it extract it to a folder. Open W7T and then select that extracted folder and it should get added to the list.
all what i have todo is run nvidia driver(for example) and chose a folder to extract it in it OR USE program like Winrar And winzip AM I RIGHT??
I really do that but it not wooooork? as you see in this picture (i use arabic version)
That folder should integrate fine however, some drivers have been purposely been programmed to not allow integration :(
"run nvidia driver(for example) and chose a folder to extract it in it", correct.
Edited by Legolash2o
