Posted (edited)
hi every one
After i make anew copy of windows 7 home premium sp1 x64 by using the legent program :thumbsup_anim: Windows 7 toolkit :dancing:
i make a search for updates ..i was expected A TWO updates only (kb971033-kb890830) BUT I WAS RONG :doh:
in the importand updates he add a 3 updates this is it..
1-kb947821 (System Update Readiness Tool) his page from microsoft http://support.microsoft.com/kb/947821
2-kb982018 his page from microsoft http://support.microsoft.com/kb/982018
3-kb2529073 his page from microsoft http://support.microsoft.com/kb/252907
and this is my tweaks file that i was used with this copy
http://www.mediafire...24111adcgm7sr7c
please heeeeeeeeelp meeeeeee :help:
Edited by abuodwan007
Posted (edited)
this is the list
updates x64\Windows6.1-KB2534111-x64.msu
updates x64\IE9.0.4-win7.msu
IE9-Windows6.1-LanguagePack-x64-trk.cab
IE9-Windows6.1-LanguagePack-x64-ara.cab
updates x64\Windows6.1-KB2425227-x64.msu
updates x64\Windows6.1-KB2479943-x64.msu
updates x64\Windows6.1-KB2503665-x64.msu
updates x64\Windows6.1-KB2507618-x64.msu
updates x64\Windows6.1-KB2509553-x64.msu
updates x64\Windows6.1-KB2511455-x64.msu
updates x64\Windows6.1-KB2532531-x64.msu
updates x64\Windows6.1-KB2536275-x64.msu
updates x64\Windows6.1-KB2536276-v2-x64.msu
updates x64\Windows6.1-KB2544893-x64.msu
updates x64\Windows6.1-KB2556532-x64.msu
updates x64\Windows6.1-KB2560656-x64.msu
updates x64\Windows6.1-KB2564958-x64.msu
updates x64\Windows6.1-KB2567680-x64.msu
updates x64\Windows6.1-KB2570947-x64.msu
updates x64\Windows6.1-KB2579686-x64.msu
updates x64\Windows6.1-KB2588516-x64.msu
updates x64\Windows6.1-KB2619339-x64.msu
updates x64\Windows6.1-KB2506212-x64.msu
updates x64\Windows6.1-KB2620704-x64.msu
updates x64\Windows6.1-KB2620712-x64.msu
updates x64\Windows6.1-KB2639417-x64.msu
updates x64\Windows6.1-KB2518869-x64.msu
updates x64\Windows6.1-KB2618451-x64.msu
updates x64\Windows6.1-KB2539635-x64.msu
updates x64\Windows6.1-KB2572077-x64.msu
updates x64\Windows6.1-KB2492386-x64.msu
updates x64\Windows6.1-KB2506014-x64.msu
updates x64\Windows6.1-KB2506928-v2-x64.msu
updates x64\Windows6.1-KB2511250-x64.msu
updates x64\Windows6.1-KB2515325-x64.msu
updates x64\Windows6.1-KB2522422-x64.msu
updates x64\Windows6.1-KB2541014-x64.msu
updates x64\Windows6.1-KB2545698-x64.msu
updates x64\Windows6.1-KB2547666-x64.msu
updates x64\Windows6.1-KB2552343-x64.msu
updates x64\Windows6.1-KB2563227-x64.msu
updates x64\Windows6.1-KB2633952-x64.msu
updates x64\Windows6.1-KB2641690-x64.msu
updates x64\Windows6.1-KB2484033-x64.msu
updates x64\Windows6.1-KB2488113-x64.msu
updates x64\Windows6.1-KB2505438-x64.msu
updates x64\Windows6.1-KB2607576-x64.msu
every one from this update i was downloaded from microsoft one by one
i think the problem is from the twaeks thats way i uploaded http://www.mediafire...24111adcgm7sr7c
Posted (edited)
after i install a untouched copy of windows i install internet explorer 9.0.4 then i make reboot
after that i make search of updates from windows update and he gave me this updates
and then i download this updates one by one from microsoft
i have agood idea for you
i well make anew windows copy with this updates without tweaks
Edited by Legolash2o
As kels said, those 3 updates appear in Windows Update because you did not include those items to be integrated. :)
P.S. I moved this thread from the request forum as it's not a request for a feature, etc... :P
@abuodwan007,
Something to keep in mind is that sometimes WU does not offer an update as appropriate until AFTER you install a different update first. So you might not get all the necessary updates offered to you the first time you check. (Like you don't get offered the IE9 updates until after you install IE9.) Also, "kb947821 (System Update Readiness Tool)" is just that, a TOOL, not an update. It's offered through the update channel, but it is not necessary and you can ignore it if you wish. But as Kel and Lego have both mentioned, if you find you didn't get the full list the first time you tested, then add the missing ones to the list and try again. What exactly are you wanting us to heeeeeeeeelp youuuuuuu do? Evaluate your list of tweaks? Why? To see if they caused the need for the "extra" updates? So what if they did? Add them and try again.
Posted (edited)
the problem has been founded
the update kb947821 (System Update Readiness Tool)
has been came in windows update becouse i was integrated nvidia graphic driver after extract it
i am not sure but i think that the updates kb982018 and kb2529073 has been came in windows update becouse i was integrated
Intel® Chipset Device Software
