Posted December 17, 201113 yr Why W7T always not responding when im closing/quit the program...1) Open W7T application2) I close W7T application before doing task with this application3) W7T not respondingCan you help me fix this prolem??this the video about my problem:W7T Problem.avi (2.16 MB)Spec of my system:- Intel Core 2 Duo 2.10 Ghz- 4 GB RAM- 160 GB HDD- Nvidia VGAThanks before and Sorry for my bad english language coz im from indonesia...
December 17, 201113 yr Whats in the Temp folder? it's usually located at C:\W7T\EDIT: Try build 82. I think you may of had a mounted folder in the above folder. Edited December 17, 201113 yr by Legolash2o
December 20, 201113 yr Author This from file "settings.txt"sMountTemp=C:\W7T\MountsSolDownload=C:\W7T\SoLoR\sW7TTemp=C:\W7Tok, i will try the last version...i hope this will fix on last version...many thanks lego for ur reply...
