XP Home does not use Mini-Setup option and the sysprep.inf will not load the unattended stuff. Pro works fine. Been a long time since I used sysprep for Home. How do you unattend the process for Home? oobeinfo.ini? Need the product key to be entered automatically.
  On 12/17/2011 at 4:12 AM, Kelsenellenelvian said:
AFAIK that feature\features were never implemented in XP Home.
I never understood why MS treated XP Home like the red head stepchild and Pro got all the goods. I was reading you could use a Winbom.ini to automate the process but not sure how to make one.
  On 12/17/2011 at 2:54 PM, Kelsenellenelvian said:
Ummm maybe because MOST home users DO NOT use any of the features in Pro?
Thus allowing MS to offer a cheaper home friendly version.
Yes totally with you there...should have said the deployment options. I know the diff between Home and Pro. Kinda sucks the Mini-Setup option was left out of Home.
