Posted January 12, 201213 yr Is it possible to remove a wa once you've compiled the image?I've changed my mind, deleted from ISO but they still show up as "Select what to install" when running iso in VBox. I'd like to remove them from the W7T installer.
January 13, 201213 yr Those seem to be silent installers, you can either just simply delete them from the DVD root (Apps folder) which is the quickest option, you can also use Registry Hive Mounter to go to HKLM\\WIM_Software\\W7T and delete the registry key.
January 14, 201213 yr Author Excellent, Thanks Lego (My fav toy when I was a lot younger than I am now!!)And just noticed you're a fellow Brit, and not that far from me, You being in Yorkshire and me a Brummie in exile in Durham! Edited January 14, 201213 yr by Legolash2o
January 14, 201213 yr Author I'm no longer live in Bridlington but in Hull at University Jeez! You know how to travel the World, don't you!!! Was that all the bus fare you could muster?? Probably the wrong place to ask this, but as I use my pre-compiled to use on many computers, the only tweak I've applied is to change the Control Panel view to small icons, but it doesn't seem to take when I've tested in VBox. Any thoughts? Edited January 14, 201213 yr by ElmerBeFuddled
January 14, 201213 yr Have you tried the latest version, you can go to the Options tab in AIO and selected Current OS and it will apply Installed windows. Also I fixed a big bug in version 89 with may have caused your issue.Yeah Hull isn't far from brid, but the university did the course i wanted so no point going further lol.
April 5, 201213 yr Author This issue has re-appeared since moving on to WinKit 1.4.xx. I can no longer see the .WA files in the Apps folder or under the HKLM\WIM_Software\W7T key.Methinks I must be doing something wrong! Edited April 5, 201213 yr by ElmerBeFuddled
