I ran the tool on a partition different than C:\ and I have as a system w7 64bit .
What I did was downloading the AIO , decompress and running into the folder where I extracted it.
I'm using an image of window 7 64bit sp1 .
I chosed to remove many things which use lot of space (natural language, slim down winsxs).
I tested on a vm and the installed size (with no hibernation/swap) changed from 7.7gb to 6.8gb.
So although it changed, it was supposed to be even slimmer.
So I'd like to know if the tool need waik (and which version?) to remove effectively the listed components and if I need to run the application from a particular folder/partition.
So the answer is that I don't need to install dism or run w7T from a particular location with the current 1.3b2 you released , is that right?
Edited by sonnet
