Hi everyone!
Lovely program by the way Lego.
To the point: im having serious problems getting registytweaks to work. By that i mean the tweaks i made myself to the registry then exported to .reg files. When trying to integrate thease with both with the registry part of All-In-One Tool and WIN Registry Editor they just won´t apply (stays at windows default). Please help me! To me this is by far the hottest feature in W7T if i could just get it to work!
Thanks
Can you please attach the registry file you're trying to import, seems like a few users are having the same issue. I don't really use this feature to notice if it's working or not but i'd sure like to fix it :)
Hi again!
I just made a new install dvd with two tweaks. one integrated with WIM Registry Editor and the other one with the addreg in All In One Tool. The one intergated with AIOT did work while the other one didn´t.
Thaks though! with one working i dont need the other :)
Posted (edited)
so the WIM Registry editor didnt work, can you tell me precisely what you do and possibly the registry file you tried to apply?
Edited by Legolash2o
I'm guessing after Registry Hive Mounter mounted the image, you didn't click Load Hives first and just went straight to Import Reg.
I've made a few changes to the RHM so it will automatically mount all hives when importing registry files.
