Posted January 21, 201213 yr i have no idea how to do Wim Registry Editor at all try 2 nothing at all adding tweaks 25 of them Hkey Local MachineHkey current userHkey usersHkey class Rooti dont understand at all which onesDefault User Registry settings for the default userSoftware HKLM\Software Windows\System32\config\softwareSystem HKLM\System Windows\System32\config\systemAdministration Registry for Administration accountComponents unknownSam HKLM\sam windows\system32\config\samwhich oneswhen selected load hives load all and import reg says invalied item please select 1! which ones does it matter i dont understand at all please help!!!!!! Edited January 21, 201213 yr by MBrys331
January 21, 201213 yr You don't really need to know, W7T will automatically mount and convert your registry file so when you first open the tool so you can just click Import straight away.The please select 1 item is a bug and i'm going to fix that now EDIT: Just noticed that the error can be ignore as it imports it fine anyway EDIT2: Fixed. Edited January 21, 201213 yr by Legolash2o
January 22, 201213 yr Author this is what i import with the toolkit that part worked verified that the list was ln the registry it was created a iso file tested it on virtual box Failed i dont know why this is happing i can add it to windows when it is up and running with out an issue and only added to install.wim file not the boot file i have no idea what the the issue is dont know how to solve it please helpWindows Registry Editor Version 5.00[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction]"Enable"="Y"[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer]"Max Cached Icons"="4096"[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]"DisablePagingExecutive"=dword:00000001[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Dnscache\Parameters]"MaxCacheTtl "=dword:00003840[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Dnscache\Parameters]"MaxNegativeCacheTtl "=dword:00000000[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]"LargeSystemCache"=dword:00000001[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem]"NtfsMemoryUsage"=dword:00000002[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters]"EnablePrefetcher"=dword:00000003[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]"EnableQuickReboot"="1"[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\StiSvc]"Start"=dword:00000002[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Widows\CurrentVersion\Policies\Explorer]"NoRemoteRecursiveEvents"="1"[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]"NoSharedDocuments"="1"[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"NoNetCrawling"=dword:00000001[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"HideFileExt"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"SeparateProcess"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_MinMFU"=dword:00000004[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_JumpListItems"=dword:00000004[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_AdminToolsRoot"=dword:00000002[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"TaskbarSmallIcons"=dword:00000001[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowMyMusic"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowHelp"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowDownloads"=dword:00000001[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_showPrinters"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowDocs"=dword:00000001[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowSetProgramAccessAndDefaults"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowUser"=dword:00000001[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowVideos"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowNetPlaces"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowMyComputer"=dword:00000001[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowNetConn"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"Start_ShowControlPanel"=dword:00000001[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer]"DesktopProcess"=dword:00000001[HKEY_CURRENT_USER\Control Panel\Mouse]"MouseHoverTime"="20"[HKEY_CURRENT_USER\Software\Microsoft\Windows Mail]"NoSplash"=dword:00000001[HKEY_CURRENT_USER\Control Panel\Desktop]"MenuShowDelay"="100"[HKEY_CURRENT_USER\Control Panel\Desktop]"MouseHoverTime"="100" [HKEY_USERS\S-1-5-19\Control Panel\Desktop]"MenuShowDelay"="2"[HKEY_USERS\S-1-5-20\Control Panel\Desktop]"MenuShowDelay"="2"[HKEY_CURRENT_USER\Control Panel\Desktop]"MenuShowDelay"="1"[HKEY_CLASSES_ROOT\*\shell\takeownership]@="Take ownership""HasLUAShield"="""NoWorkingDirectory"=""[HKEY_CLASSES_ROOT\*\shell\takeownership\command]@="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F""IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"[HKEY_CLASSES_ROOT\exefile\shell\takeownership]@="Take ownership""HasLUAShield"="""NoWorkingDirectory"=""[HKEY_CLASSES_ROOT\exefile\shell\takeownership\command]@="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F""IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"[HKEY_CLASSES_ROOT\dllfile\shell\takeownership]@="Take ownership""HasLUAShield"="""NoWorkingDirectory"=""[HKEY_CLASSES_ROOT\dllfile\shell\takeownership\command]@="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F""IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"[HKEY_CLASSES_ROOT\Directory\shell\takeownership]@="Take ownership""HasLUAShield"="""NoWorkingDirectory"=""[HKEY_CLASSES_ROOT\Directory\shell\takeownership\command]@="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t""IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /
January 22, 201213 yr Fixed the issue stopping it from adding into the image, it will also fix some addon issues too
January 22, 201213 yr Fixed the issue stopping it from adding into the image, it will also fix some addon issues too v95, right?
