compstuff Posted January 21, 2012 Posted January 21, 2012 I thought I read this somehwere here before and I am reading info about Ricks solution so I am wondering if W7T has the ability or already injects the autounattend.xml directly to the boot.wim image index 2 Quote
RicaNeaga Posted January 21, 2012 Posted January 21, 2012 Yes, it's in v95 and it's working You just have to use the FULL integration of the unattended .xml file from rthe WIM Manager Quote
nice_guy75 Posted January 21, 2012 Posted January 21, 2012 Yes, it's in v95 and it's working You just have to use the FULL integration of the unattended .xml file from rthe WIM Manager For this, do we have to select Boot.wim instead of install.wim? Quote
RicaNeaga Posted January 21, 2012 Posted January 21, 2012 Nope, the FULL option does that. You just have to select the install.win or the dvd folder from the AIO or from the WIM Manager. Quote
nice_guy75 Posted January 21, 2012 Posted January 21, 2012 I am extremely sorry, but where is this "FULL" option? Quote
RicaNeaga Posted January 21, 2012 Posted January 21, 2012 After pressing the Apply Unattended, a Full option appears. Press it after selecting the .xml file. And pray that it works (joking) Quote
