Posted January 21, 201213 yr 7-ZipDescription7-Zip is a file archiver with a high compression ratio.What's new after 7-Zip 9.25 alpha:- LZMA2 now is default compression method for .7z format.- 7-Zip now can update WIM archives.- 7-Zip File Manager now can move files to archives.- 7-Zip File Manager now can calculate CRC-32, SHA-1 and SHA-256 checksums for files.- The default encoding for TAR format now is UTF-8. You can use -mcp=1 switch for OEM encoding.- Command line version: - new "rn" command to rename files in archive. - new -sdel switch to delete files after including to archive. - new -sns switch to store NTFS alternate streams (for WIM format only). - new -sni switch to store NT security information for files (for WIM format only). - new -stl switch to set archive timestamp from the most recently modified file.- Speed optimizations for opening big archives and big disk folders.- DMG support was improved- Some bugs were fixed.- New localization: Aragonese.- 7-Zip now shows warning message, if the archive has wrong file name extension.- new -stl switch.Version: 9.29Platform: x86 & x64Addon Release Date: October 9, 2012Uninstallable: YesCredit: *Reaper*NOTE: These addons are for the DX WinNT6.x True Integrator and Windows 7 Only.NOTE: To install on a running system, extract the addon and right-click on the .inf file and choose install. 2.23 MB 9eb77367b85098ef9ec849d4cb38188eEnjoy! Edited October 10, 201212 yr by *Reaper*
