Posted January 22, 201213 yr I am very pleased with lasted changes in SoLoR updates downloader, but i notice bug, if i select Additions on list i don't see Hotfix Client/Extended for x86 only x64. Also very usefull option will be to sort by colum i click, like date, folder, file, size etc...Thanks.
January 22, 201213 yr Those are for .net framework 4 and cannot be integrated into win7I maintain a slim .net4 installer with all the updates integrated http://www.wincert.net/forum/index.php?showtopic=9154
January 22, 201213 yr Ricktendo, am i allowed to provide a link to your .Net installer on the 'Downloads' tab?
January 22, 201213 yr Author @Rick i know, i am not mean in that way, i found this W7T downloader very usefull when downloading all stuff need for my needs, otherwise i must copy every link from solor repository to jdownloader and then check what i downloaded, very borring stuff. Reason i not use your installer is because i use Net4 Client Prfofile only and use your core (slim instaler on solor repository) and integrate downloaded hotfixes manually, i have some reason for it.I just want to have downloader which can download everything from solor repository as is, and it have option to sort by date, folder.... colums that have, nothing else. Legolash2o is that possible ?Thanks. Edited January 22, 201213 yr by shon3i
January 22, 201213 yr Author Yep i know, but still cilent only is less file size (about 5-6mb) and that is huge for someone who want to put a lot of stuff and keep DVD5 size of installation
January 26, 201213 yr SoLoR updates will now show x86 versions of the Additions, silly bug really...The ordering of columns will probably come after 1.3.0
March 3, 201213 yr Author One more req if possible for solor downloader, when i select some group ie additions, and select all updates to download, can W7T automaticly make subfolders like are on server to make not conflict files with duplicate names, that will overwritte in download.Thanks
March 8, 201213 yr Done, W7T will download files to the correct folder hierarchy on the SoLoR server, it will also sort out already downloaded file. For example, all the updates which go into the 'LDR Placeholder' folder on the website will be moved into the 'LDR Placeholder' folder on your HDD.
