OnePiece's Adobe Flash Player ActiveX for XP (x86)/Vista (x86 & x64)/Seven (x86 & x64)/8 (x86 & x64) True Addon Maker
Create OnePiece Adobe Flash Player True AddOn
tabdownload.png Update (11 September 2014)
Hash MD5 F58AD5AD3C67D4646074F713799E56DE
Filesize: 117 KB (120085 bytes)
This tool allows you to create an updated "true mode" (means directly slipstreamed without installation to your source by changing original flash files) addon of Adobe Flash Player ActiveX Internet Explorer control to be integrated in your Windows XP 32 bit/Vista 32/64 bit/Seven 32/64 bit/8 32/64 bit source.
It can be also integrated in a Windows 2003 source but in this case you need to extract entries.ini file from the addon and modify it by changing
[Sysoc];;SWFlash=ocgen.dll,OcEntry,SWFlash.inf,,7 ;;; --> Windows Server 2003
in
[Sysoc]SWFlash=ocgen.dll,OcEntry,SWFlash.inf,,7
For integrating addon in Windows XP and 2003 latest release of RVM Integrator or Nlite is required. For Vista, 7 and 8 images you need DX WinNT6.x Integrator instead.
How to create and update an Onepiece's Flash Player activeX Addon BY YOURSELF:
First install newer Flash Player ActiveX in a running system (or VM).
Download "Create OnePiece Adobe Flash Player True AddOn" (you don't need to download it every time Flash is updated), run it in the same system you've installed Flash ActiveX and in a few seconds you'll get an updated Flash ActiveX true addon.
  • 4 months later...
Updated.
Now you can get a Windows 8 compatible true addon.
Here' s an example of what you can do easily by yourself:
http://sdrv.ms/PIijkI
https://docs.google.com/open?id=0B5EBubruZ8REY0dFYWZWV2d3akk
https://www.dropbox.com/s/1324p8c8a5w10p0/OnePiece_Adobe_Flash_Player_v11.3.300.270_True_AddOn_CBF9C8BB65BAC8ACCC587E4CD7D66DD6.cab?dl=1
(MD5 hash: CBF9C8BB65BAC8ACCC587E4CD7D66DD6 )
  • 4 weeks later...
Thank you for this great tool. I get this error when I run the command.
1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
The system cannot find the file specified.
1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
Cabinet Maker - Lossless Data Compression Tool
13,933,864 bytes in 3 files
Total files: 3
Bytes before: 13,933,864
Bytes after: 4,809,964
After/Before: 34.52% compression
Time: 22.69 seconds ( 0 hr 0 min 22.69 sec)
Throughput: 599.68 Kb/second
16,730,362 bytes in 9 files
92.64% - Flash64.cab (9 of 9)
Edited by dotfusion
ignore it, and everything is OK
however make sure you always have latest version, I think you've already installed yesterday latest version 11.4.402.287 right?
Ciao.
Edited by OnePiece
  • 9 months later...
done with Flash Player Active X 32bit True Addon Maker:
OnePiece Adobe Flash Player v11.8.800.94 True AddOn
tabdownload.png Update (July 10 2013)
Hash MD5 12FA1D795DD9A2E6EE80FD57DC39CFDB
Filesize: 8.07 MB (8468951 bytes)
