Posted January 22, 201213 yr Onepiece's Microsoft .NET Framework 4.0 TRUE Addon for Windows XP, Windows 2003, Windows Vista x86 and Windows 7 x86 OnePiece Microsoft.NET Framework v4.0.30319.2102 True AddOn ENU Update (22 June 2017) Update (22 June 2017) Update (22 June 2017)Hash MD5 F376A61FF77483BF04A748DCF160270FFilesize: 42.22 MB (44274780 bytes) This DX WinNT6.x Integrator addon is compatible with Windows Vista and 7 x86 (32 bit) versions (for XP/2003 you must use latest releases of RVM Integrator or Nlite). The peculiarity of this addon is that .NET framework is directly slipstreamed into your Windows source, without the need of running .msi files or svcpack/runonce installations, a "true addon" integration just like .net 1.0 in Windows Server 2003. So you'll get a working .NET framework already installed BEFORE T-13 (svcpack time), a very handy opportunity. How to update the DotNet True AddOn Edited June 22, 20177 yr by nonno fabio
February 16, 201213 yr Great job! Thanks!One request, though: Any chance of a x64 version of this add-on? Edited last question cause it got answered in another thread....
March 8, 201213 yr Author New .net4 true addon links are online.Update is suggested as Microsoft has fixed a lot of bugs with this release.
July 12, 201212 yr Author Updated releases will be uploaded soon. In the meantime they are already available in Onepiece's Skydrive
October 9, 201212 yr Thanks for this True AddOn :prop: I cuurently working on a new build of Windows 7 x64 SP1-U and I have just a couple of question before I commit to this wonderful addon.1. Does your add on include hotfixes such as those found in Ricktendo64's switchless installer?2. Are you working on a Microsoft .NET Framework 4.5 full true addon?3. Do recomend also adding OnePiece .NET 3.5 along side with 4.0?4. Is .NET 3.x and 2.0 installed by default with Win 7 x64?Any insight would be much appreciated? Edited October 9, 201212 yr by dotfusion
October 9, 201212 yr 1. Does your add on include hotfixes such as those found in Ricktendo64's switchless installer?Hi dotfusion, Yes, the DotNet40 True AddOn and Full update, but this AddOn and only for Windows x323. Do recomend also adding OnePiece .NET 3.5 along side with 4.0?No, DotNet 4 True AddOn is not never been tested in WIndows NT6.x (Vista/Seven ect ect)4. Is .NET 3.x and 2.0 installed by default with Win 7 x64?Yes, if I remember correctly (easy to verify see this destination "C:\Windows\Microsoft.NET\Framework\v3.5")2. Are you working on a Microsoft .NET Framework 4.5 full true addon?No, I'm not working in DotNet45 True AddOn, I really miss the time, I have a hard keep up to date or that this all addon alreadyCiao. Edited October 9, 201212 yr by OnePiece
October 9, 201212 yr Hi dotfusion, Yes, the DotNet40 True AddOn and Full update, but this AddOn and only for Windows x32I appreciate the time your taking to answer my trivial questions. You have helped to understand sooo much :worthy: ooops. x32 is for x86 intergration only.Can you recomend a .NET x64 true addon or SvcPack addon compatible with NT6.x true integrator. Perhaps my only option is Ricks switchless installer?
October 10, 201212 yr Is right, the Dotnet40 X64 of Ricks and Ok, but that's an .EXE (Silent Installer), ask Ricks how to do svcpack addon, or commands to use in svcpack addon ect ectand very simple serves a entire.ini and folder svcpack (and copy the xxx.exe file inside), download and extract my mozilla addon (the old one), and see how fate, and very simple you can do it yourself once a svcpack addonCiao. Edited October 10, 201212 yr by OnePiece
October 10, 201212 yr @OnePieceThis is my first attemp at making a SVCPACK addon. Can you please verify my syntax and folder structure. Also I would like to know if the commenting syntax is ok to use as follows. Thanks again.DotNet4_addon.cab (Compressed with DX CAB Tools)../SVCPACK/dotNetFx40_Full_x86_x64_SlimSetup.exe../dotnet_entries.inidotnet_entries.ini[general]title = .NET 4.0 ;<-- requireddescription = .NET Framework switchless installer ;<-- requiredversion = 4.0 ;<-- requiredbuilddate = 03/13/2012 ;<-- requiredcompany = Microsoft Corporation ;<-- optionalcopyright = Microsoft Corporation ;<-- optionalwebsite =http://www.wincert.net/forum/index.php?/topic/9154-slim-net-framework-4-full-x86x64-3-13-2012/ ;<-- optionalcustomizedby = ricktendo64 ;<-- optionallastupdatetime = 03/13/2012 ;<--optionallanguage = neutal ;<--optionalreleasetype = SVCPACK Addon ;<-- mandatory (addon type);processorarchitecture = x86 ;<-- optional. "x86" for x86-only platforms; "x64" for x64-only platforms; omit if platform-neutral.[AddProgram]dotNetFx40_Full_x86_x64_SlimSetup.exe /y ;<-- switchless EXE Edited October 10, 201212 yr by dotfusion
October 10, 201212 yr Now I remember, you need to useSilent "No GUI" SFX alternative v1.4:http://adf.ly/1713566/dotnet4sfxngto create the dotNetFx40_Full_x86_x64_SlimSetup.exe for SvcPack AddOn, ask Ricks for more infoin all these line need to remove the ":" (semicolon);****="hidcon:reg copy HKLM\\SYSTEM\\Setup HKLM\\SYSTEM\\Setup\\SSIPRS /f";****="hidcon:reg add HKLM\\SYSTEM\\Setup /v SystemSetupInProgress /t REG_DWORD /d 0 /f";****="hidcon:reg copy HKLM\\SYSTEM\\Setup\\SSIPRS HKLM\\SYSTEM\\Setup /f";****="hidcon:reg delete HKLM\\SYSTEM\\Setup\\SSIPRS /f"in****="hidcon:reg copy HKLM\\SYSTEM\\Setup HKLM\\SYSTEM\\Setup\\SSIPRS /f"****="hidcon:reg add HKLM\\SYSTEM\\Setup /v SystemSetupInProgress /t REG_DWORD /d 0 /f"****="hidcon:reg copy HKLM\\SYSTEM\\Setup\\SSIPRS HKLM\\SYSTEM\\Setup /f"****="hidcon:reg delete HKLM\\SYSTEM\\Setup\\SSIPRS /f"because otherwise the svcpack addon does not workRicks in readme.txt wrote:If you are going to repack this installer for SVCPACK install enable ALL the following lines by removing semicolon in config.txt, so the config file must be so;!@Install@!UTF-8!;Default Full w/o install promptGUIMode="2"RunProgram="hidcon:reg copy HKLM\\SYSTEM\\Setup HKLM\\SYSTEM\\Setup\\SSIPRS /f"RunProgram="hidcon:reg add HKLM\\SYSTEM\\Setup /v SystemSetupInProgress /t REG_DWORD /d 0 /f"RunProgram="netfx_core_%%P.msi /update \"%%T\\KB2468871-v2-%%P.msp\" /qn";RunProgram="netfx_corelp_%%P.msi /qn"RunProgram="netfx_extended_%%P.msi /update \"%%T\\KB2468871-v2-%%P.msp\" /qn";RunProgram="netfx_extendedlp_%%P.msi /qn"RunProgram="hidcon:reg copy HKLM\\SYSTEM\\Setup\\SSIPRS HKLM\\SYSTEM\\Setup /f"RunProgram="hidcon:reg delete HKLM\\SYSTEM\\Setup\\SSIPRS /f";[/ai | SHIFT] Client ONLY w/o progress barAutoInstall="hidcon:reg copy HKLM\\SYSTEM\\Setup HKLM\\SYSTEM\\Setup\\SSIPRS /f"AutoInstall="hidcon:reg add HKLM\\SYSTEM\\Setup /v SystemSetupInProgress /t REG_DWORD /d 0 /f"AutoInstall="netfx_core_%%P.msi /update \"%%T\\KB2468871-v2-%%P.msp\" /qn";AutoInstall="netfx_corelp_%%P.msi /qn"AutoInstall="hidcon:reg copy HKLM\\SYSTEM\\Setup\\SSIPRS HKLM\\SYSTEM\\Setup /f"AutoInstall="hidcon:reg delete HKLM\\SYSTEM\\Setup\\SSIPRS /f";[/aic] Client ONLY w/o progress barAutoInstallc="hidcon:reg copy HKLM\\SYSTEM\\Setup HKLM\\SYSTEM\\Setup\\SSIPRS /f"AutoInstallc="hidcon:reg add HKLM\\SYSTEM\\Setup /v SystemSetupInProgress /t REG_DWORD /d 0 /f"AutoInstallc="netfx_core_%%P.msi /update \"%%T\\KB2468871-v2-%%P.msp\" /qn";AutoInstallc="netfx_corelp_%%P.msi /qn"AutoInstallc="hidcon:reg copy HKLM\\SYSTEM\\Setup\\SSIPRS HKLM\\SYSTEM\\Setup /f"AutoInstallc="hidcon:reg delete HKLM\\SYSTEM\\Setup\\SSIPRS /f";[/aif] Client + Extended w/o progress barAutoInstallf="hidcon:reg copy HKLM\\SYSTEM\\Setup HKLM\\SYSTEM\\Setup\\SSIPRS /f"AutoInstallf="hidcon:reg add HKLM\\SYSTEM\\Setup /v SystemSetupInProgress /t REG_DWORD /d 0 /f"AutoInstallf="netfx_core_%%P.msi /update \"%%T\\KB2468871-v2-%%P.msp\" /qn";AutoInstallf="netfx_corelp_%%P.msi /qn"AutoInstallf="netfx_extended_%%P.msi /update \"%%T\\KB2468871-v2-%%P.msp\" /qn";AutoInstallf="netfx_extendedlp_%%P.msi /qn"AutoInstallf="hidcon:reg copy HKLM\\SYSTEM\\Setup\\SSIPRS HKLM\\SYSTEM\\Setup /f"AutoInstallf="hidcon:reg delete HKLM\\SYSTEM\\Setup\\SSIPRS /f";[/ain] Client + Extended + ngen w/o progress barAutoInstalln="hidcon:reg copy HKLM\\SYSTEM\\Setup HKLM\\SYSTEM\\Setup\\SSIPRS /f"AutoInstalln="hidcon:reg add HKLM\\SYSTEM\\Setup /v SystemSetupInProgress /t REG_DWORD /d 0 /f"AutoInstalln="netfx_core_%%P.msi /update \"%%T\\KB2468871-v2-%%P.msp\" /qn";AutoInstalln="netfx_corelp_%%P.msi /qn"AutoInstalln="netfx_extended_%%P.msi /update \"%%T\\KB2468871-v2-%%P.msp\" /qn";AutoInstalln="netfx_extendedlp_%%P.msi /qn"AutoInstalln="hidcon:%windir%\\Microsoft.NET\\Framework\\v4.0.30319\\ngen executequeueditems /nologo /silent"AutoInstalln="x64:hidcon:%windir%\\Microsoft.NET\\Framework64\\v4.0.30319\\ngen executequeueditems /nologo /silent"AutoInstalln="hidcon:reg copy HKLM\\SYSTEM\\Setup\\SSIPRS HKLM\\SYSTEM\\Setup /f"AutoInstalln="hidcon:reg delete HKLM\\SYSTEM\\Setup\\SSIPRS /f";!@InstallEnd@!just read the README.txt inside the dotNET4sfxNoGUI1.4.7zto create the SFX archive and very simple, just write to a file cmd this linecopy /b 7zS.sfx + config.txt + dotNetFx40_Full_x86_x64_SlimSetup.7z dotNetFx40_Full_x86_x64_SlimSetup.exeafter you take the dotNetFx40_Full_x86_x64_SlimSetup.exe and create SvcPack AddOn, like you did beforeCiao. Edited October 10, 201212 yr by OnePiece
April 18, 201510 yr Seems that the Microsoft Update is not been updated and still requires hotfix\update obsolete, so those who want to fix the problem until the Microsoft Update puts everything in place, just integrate with nLite or RVMi after the DotNet True AddonOnePiece Microsoft.NET Framework v4.0.30319.1031 Fix MU True AddOn Update (17 April 2015) Update (17 April 2015) Update (17 April 2015) Update (17 April 2015) Update (17 April 2015)Hash MD5 45EF4DEC9BED9437625C7CC22CBE9E44Filesize: 1018 bytes (1,018 bytes)or open notepad and copy this lineWindows Registry Editor Version 5.00[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Updates\Microsoft .NET Framework 4 Client Profile\KB2894842v2]"ThisVersionInstalled"="Y";"ARPLink"="HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\{3C3901C5-3455-3E0A-A214-0B093A5070A6}.KB2894842v2";"InstalledBy"="OnePiece";"InstalledDate"="";"InstallerName"="Windows Installer";"InstallerVersion"="4.05";"PackageName"="Security Update for Microsoft .NET Framework 4 Client Profile (KB2894842v2)";"PackageVersion"="2";"Publisher"="Microsoft Corporation";"PublishingGroup"="Developer Division";"ReleaseType"="Security Update"[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Updates\Microsoft .NET Framework 4 Extended\KB2894842v2]"ThisVersionInstalled"="Y";"ARPLink"="HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\{0A0CADCF-78DA-33C4-A350-CD51849B9702}.KB2894842v2";"InstalledBy"="OnePiece";"InstalledDate"="";"InstallerName"="Windows Installer";"InstallerVersion"="4.05";"PackageName"="Security Update for Microsoft .NET Framework 4 Extended (KB2894842v2)";"PackageVersion"="2";"Publisher"="Microsoft Corporation";"PublishingGroup"="Developer Division";"ReleaseType"="Security Update"save as FixMU.reg, and after running itCiao a tutti.
