Posted January 23, 201213 yr Notepad2 (modified)NOTE: This will "replace" the original notepad.exe in windows. Technically, it does not replaceit. The original notepad.exe will still be on your system, however, anytime you open a compatible file, it will open using notepad2, instead of the original notepad.exe. See the homepagefor a more details.DescriptionMost editors are either fully-featured but slow or fast but useless. Notepad2 has a small footprint and is very fast,even when used on a very old machine; the only other text editor that I have used that starts up as fast as Notepad2 is Windows Notepad. Yet, despite its speed, Notepad2 has a lot of useful features, such as auto-indent, brace matching, syntax highlighting, and code folding. Most importantly, its startup speed is comparable to that of Windows Notepad, which makes Notepad2 an ideal Notepad replacement.Modifications compared to the official Notepad2:•Code folding•Support for bookmarks•Option to mark all occurrences of a word•Word auto-completion•Syntax highlighting support for AutoHotkey, AutoIt3, AviSynth, Bash, CMake, Inno Setup, LaTeX, Lua, Markdown, NSIS, Ruby and Tcl scripts•Improved support for NFO ANSI art•Support for replacing Windows Notepad using a clean, unintrusive registry-based method•Other various minor changes and tweaksVersion: 4.2.25.796Platform: x86 & x64Addon Release Date: March 5, 2012Uninstallable: YesCredit: *Reaper*NOTE: These addons are for the DX WinNT6.x True Integrator and Windows 7 Only.NOTE: To install on a running system, extract the addon and right-click on the .inf file and choose install. 884 kb e8b6fc6ab78c2609cbad1896fa5fc673Enjoy! Edited October 10, 201212 yr by *Reaper*
October 9, 201212 yr Thanks for this True AddOn. When I try to add this to addon, NT6.x simply ignares it and doesnt populate the list. No error is message is offered. Hash OK. Edited October 9, 201212 yr by dotfusion
October 9, 201212 yr Just tested everything looks Ok ??;;used the boot.wim because my pc and slow, but the addon will behave exactly even with the install.wim2012-10-09 17:22:59 : Mounting image - 1~Microsoft Windows PE (x64)~Microsoft Windows PE (x64)~1,187,717,206 bytes~x64~<undefined>~6.2.9200~16384~0~WindowsPE~WindowsPE~WinNT~~WINDOWS~2964~13130~7/26/2012 - 8:39:55 AM~7/26/2012 - 10:05:21 AM~en-US (Default)~D:\HRM_CCSA_X64FRE_EN-US_DV5\sources\boot.wim~D:\MountDir_TMP2012-10-09 17:23:35 : The operation was successful.2012-10-09 17:28:22 : Adding package Notepad22012-10-09 17:28:22 : Processing 1 of 1 - Adding package Notepad2~~True AddOn~English~4.2.25.720~© 2012 Florian Balmer~*Reaper*~http://code.google.com/p/notepad2-mod/ - C:\Reapers.Notepad2.v4.2.25.720.Windows7.True.AddOn.cab2012-10-09 17:28:28 : The operation was successful.choose IGNORE-CHECK (in ComboBox), add the addon and click Apply, see later in %Temp%\WinNT6TI.log" what it says?Ciao. Edited October 9, 201212 yr by OnePiece
