Posted January 26, 201213 yr CCleanerDescriptionCCleaner is a freeware system optimization, privacy and cleaning tool. It removes unused files from your system - allowing Windows to run faster and freeing up valuable hard disk space. It also cleans traces of your online activities such as your Internet history. Additionally it contains a fully featured registry cleaner. But the best part is that it's fast (normally taking less than a second to run) and contains NO Spyware or Adware!v3.22.1800 (24 Aug 2012) - Added full support for Windows 8. - Improved Startup Item tool compatibility. - Improved benchmarking for Cleaner summary results. - Improved support for Custom Files and Folders. - Improved file security algorithms. - Added option to Exclude a single registry value. - Improved wildcard support in search boxes. - Fixed support for Windows 2000. - Minor GUI improvements. - Minor bug fixes.Version: 3.22.1800Addon Release Date: August 31, 2012Platform: x86 & x64Uninstallable: YesCredit: *Reaper*NOTE: These addons are for the DX WinNT6.x True Integrator and Windows 7 Only.NOTE: To install on a running system, extract the addon and right-click on the .inf file and choose install. 3.15 mb 3dfc86f400bfb959c85697b0ec428460Enjoy! Edited September 1, 201212 yr by *Reaper*
